95 Ody wont keep running
Hello guy.....I really need help....
any advice is greatly appreciated.
This is my 95 Honda Odyssey 2.2L ..
The problem is that the engine is hard to keep running after the initial start.
It takes mutable tries to get the engine to keep running.
Though after it finally starts it will run absolutely fine..to the point there is
no indication that there is a problem what so ever...doesn't even run ruff,stall,or have a loss of power...
I mean it runs perfect and starts every time.
(after it has finally started and warmed up.)
I have let the car sit for as long as 6 hours...and it will start right up.
If it sits more than 7 hours..same starting problem.
However,some mornings it starts first try.
Im stumped..never seen such a thing.
I have changed/cleaned in the last few days:
cap,rotor,wires,cleaned the IAC valve,cleaned fast idle thermo valve,Sea foamed the intake,new ngk plugs,new ignition switch pig tail,egr and rails cleaned,new temp sensor,coolent system bled and new radiator cap.
Someone please help...this is driving me nuts!! Thanks in advance
http://www.youtube.com/watch?v=S-82K...ature=youtu.be
Ohmster
11
Jul 21, 2015 07:14 AM
redm3turbo
Mar 19, 2013 06:59 PM
BoRiCuA
Aug 1, 2007 10:08 PM
