Gear not Engaging
Old Sep 9, 2012 | 11:48 PM
John 07's Avatar
Default Gear not Engaging
Tried to drive the R today. While driving first gear works fine and when i try to shift from 2nd to third the gear doesnt go in. Feels like its blocked. In another words it feels like im trying to shift without pressing the clutch. I also had this happen from third to fourth gear. I tried to warm up the car but isnt doesnt seem to help. Possibility of the clutch going bad? what do you guys think?
Old Sep 10, 2012 | 11:07 PM
dimo92's Avatar
Default Re: Gear not Engaging
had same problem, didnt want to go into second. pulled off the trans, one of the springs on the clutch disk broke.
Old Sep 11, 2012 | 03:36 AM
Just a n00b's Avatar
Accident Prone
What I'm thinking.
OP, time for a new clutch...
Old Sep 11, 2012 | 08:37 AM
d=f20c1's Avatar
I'm having a similar problem with my car.........it goes into every gear, it's just that I have to push it in a lot harder than normal. Any input?
Old Sep 11, 2012 | 03:00 PM
parts@synchrotech's Avatar
You may have a worn 3-4 sleeve set. A common problem with most B-Series transmissions.
Old Sep 11, 2012 | 07:18 PM
IN VTEC's Avatar
If the clutch pedal pressure hasn't gotten stiffer and engaging lower and the resistance is very gear-specific, then it's most likely the synchro set/gear. Third and fourth are on the same synchro set so it's not unusual to lose the opposing paired gear when one is damaged.
JDMGSR-T
Oct 27, 2006 02:48 PM
shorty10388
Sep 17, 2005 12:49 PM
eMbrace
May 14, 2005 07:47 AM
SatinSilver_DC5
May 3, 2005 05:29 AM
Chief Brody
Aug 4, 2004 09:28 PM
