1997 honda civic dc po133 codes
Old Sep 9, 2012 | 06:59 PM
97civicdx's Avatar
Default 1997 honda civic dc po133 codes
I constantly get the slow response code on my 97 dx. Its the d-16y7 and it has around 200k miles on it. Fuel injectors are original too. Please do not just reply REPLACE O2 SENSOR................. I have already done this numerous times and code still continues. Is there a check list for finding the cause of this code?
Old Sep 9, 2012 | 07:27 PM
Former User's Avatar
Default Re: 1997 honda civic dc po133 codes
Check for an exhaust leak.
Old Sep 10, 2012 | 03:19 AM
97civicdx's Avatar
I have already replaced the entire exhaust system. Newer cat and midpipe and rear muffler.
Old Sep 10, 2012 | 05:09 AM
Aftermarket exhaust system? The part of the stock exhaust system relevant to P0133 is the header/cat unit.
Old Sep 10, 2012 | 08:47 AM
97civicdx's Avatar
Entire exhaust, cat too. Its a Bosal replacement unit. Before u fault it for the codes, let me just say that the slow response code was also present in the oe honda cat that was original to the car.
I am believing that the actual fault can lie in a faulty fuel injector or injectors.
Old Oct 2, 2012 | 04:49 PM
97civicdx's Avatar
Just realized that it tends to happen more when im running with the AC system on.........
Old Oct 3, 2012 | 04:21 PM
97civicdx's Avatar
RonJ@HT: Do you have a trouble shooting page on the po133 code for a 1997 Honda Civic dx. Its the d-16y7 engine and 5 speed manual trans.
Old Oct 3, 2012 | 04:28 PM
Old Oct 4, 2012 | 01:15 PM
97civicdx's Avatar
Okay, Thanks. Ive already done this many times. The problem is more complex than this flow chart I guess.
Would u happen to have the trouble sheet for testing fuel injectors. both Resistance readings test levels and
Old Oct 4, 2012 | 01:47 PM
The text below from the diagram suggests that you should look for a poor electrical connection in the O2 sensor connector or the ECU connector.
blacktibby07
Feb 7, 2011 05:21 PM
Chiggah
Aug 22, 2009 10:11 AM
Frostwhite_DB8
Jun 2, 2007 09:33 AM
LillDragun
Jul 11, 2002 05:47 PM
