d16y8 dipstick relocation
got a d16y8 i picked up for $100 and i'm currently rebuilding it. I wanna use a z6 oil pump. can the block be drilled out and have a z6 dipstick tube installed in the z6 location? or am i stuck with using a obd2 pump that has the dipstick inside of it.
thanks
thanks
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/i-want-install-z6-oil-pump-my-y8-fitment-pickup-dipstick-questions-2868456/
If you want to do it because you think the Z6 oil pump pushes more oil, you are incorrect.
You can port and shim a y8 pump to help with the lack of oil holes... also you can increase your clearences on the crank alittle to help with oil. The y8 had alittle tighter clearences on the crank.
Try and find blocks that people have snaped rods or such in.. I find them around me all the time for 50 bucks, get the crank micro polished
r0iand
Apr 27, 2010 07:11 PM
apekd
Aug 13, 2009 05:23 PM
