D16z6 with 2 dipsticks...
Just bought a d16z6 block for a good deal. I looked at it at home and realized it has two dipsticks. One where it's supposed to be. And one where the d16yxs are located. Which from what I read, means it has the d16yx oil pump. I don't know who's the dumbass who set that up.. Let's hope it doesn't have the y7/8 crank in it also...
So my question is, should I get a z6 oil pump? Or is it not a big deal to worry about? I plan on boosting this in the near future. And I don't know if I should worry about the oil pressure and this issue. I also found out the two pumps are near identical other than the dipstick. So I'm mostly just focusing on the factor of the two dipsticks
I guess someone thought it would be a good idea to double check their oil lol. I'll upload a pic when I get home later today.
So is it a bad idea to boost with 2 dipsticks lol?
Keyboard Humorist
Re: D16z6 with 2 dipsticks...
Both crank and oil pump aren't as good as the Z6.
The Y8 pump puts out about 30% less cfm - you can verify this in the shop manual.
The Y8 crank has one oil hole per journal while the Z6 crank has 2 oil holes per journal.
And to the other response about dipsticks having no effect on turbos. I read something about the oil pressure with turbos and why I should be concerned about the dipstick. But there's no sense I can make of that. Now that's besides the point since I'll be getting a new one.
And I still intend on posting pictures when I can for amusement
No **** it only has one purpose lol. It still has to hold in the pressure though. I don't know why what I read said that about the dipstick and that it could be a problem. I just read it on this forum or d series so I had to ask
It would give ya options if your future plan includes running a turbo manifold that would make it hard impossible to check your oil.
If you have a good OEM y8 oil pump get it ported and that should work no need to buy another pump, unless damaged.
As for the crank if you are not build a 300bhp+ setup the y8 crank will work if you have a port y8 pump.
Yeah I thought about that. I'll just have to wait and figure it out. I just don't like the thought of having two. And I haven't even had time to check the crank yet.
Here's the picture for laughs. Two dipsticks for one dipshit
Attachment 335450
Attachment 335450
Just tell them its twin dip lol
But yea looks like a y pump on a z6.
For those that are fighting the z6 has better oiling over the y motors. Case and point.
Yeah. I suppose this means the oil pump goes with the oil pan? I never thought much of that when I saw it was a y pan. Wasn't worried though. I only paid $47 for the short block
Not sure how important the bolts for the oil pump part. I have the absolute worst vocabulary memory. But yeah, half the oil pan studs were bolts. So I'm assuming a couple of them were from there.
The good news is I have a z6 crank
