battery relocation trouble.
Old Sep 8, 2012 | 04:16 PM
nxtNMkillaB's Avatar
Default battery relocation trouble.
i recently relocated my battery into my trunk.
i used 2gauge from the positive to a power distribution block under the dash.
from there i have 2 gauge to the starter
and a 4 gauge to the fuse box.
my fuse box is also relocated under my dash, so i had to extend the alt. wire to reach.
my car only starts with a VERY freshly charged battery. or with a jump.
if the battery is even 12.3-12.5 volts the car will only crank and not fire.
the engine still sounds like its cranking fast.
i have less than a .01 volt drop between the battery and the fues box.
so to sum it all up my car cranks. and it only starts with 12.8v or more.
any in put is greatly appreaciated.
Old Sep 12, 2012 | 02:03 AM
jwatsoncrx91's Avatar
Default Re: battery relocation trouble.
If I remember correctly a 12 volt battery should be at atleast 12.6 but ideally 12.8. I know a brand new 12 volt battery typically reads about 13.4 volts
Last edited by jwatsoncrx91; Sep 12, 2012 at 02:05 AM. Reason: remembered more information
Old Sep 12, 2012 | 04:24 PM
nismo2evoawd's Avatar
Well whats the cca of the battery and how old is it?
notnic3
Jun 12, 2017 11:26 AM
toner297
Honda Civic (2001 - 2005)
12
May 24, 2011 12:39 AM
_Phenom_
Mar 24, 2010 03:16 PM
4G92
Nov 12, 2007 09:32 AM
Ruben19
Oct 10, 2007 08:49 AM
