No start - B16A2 - EM1
Old Sep 6, 2012 | 07:19 PM
purgat0ry's Avatar
Default No start - B16A2 - EM1
http://youtu.be/hbIsQBZvjuQ
No start as you can see.
I've got a few ideas as to what the issue could be, but I'm not positive yet.
Timing, maybe? Mechanical was double checked before it was put back together, the Crank pully was never removed from the crank, merely the timing belt removed for the head gasket replacement.
That question thread can be seen here
Opinions?
Old Sep 7, 2012 | 06:31 AM
purgat0ry's Avatar
Default Re: No start - B16A2 - EM1
bump?
Old Sep 7, 2012 | 06:38 AM
jbpnoman's Avatar
Basic no-start diagnosis. Test fuel pressure at the filter. Pull plugs, inspect, and verify bright white spark at all four. Does your CEL come on for 3 seconds when you turn the key to ON (II)?
Old Sep 7, 2012 | 06:57 AM
purgat0ry's Avatar
CEL does come on for 3 sec when the key is set to ON
As for Fuel, I don't want to make assumptions, but nothing involving the fuel system was touched and known working before hand; I'll add that to the list of crap to check though.
Plugs were cleaned before re-installation and have less than 10k miles on them and were gapped properly; I'll verify spark while cranking though (I really need a second set of hands, damn)
Old Sep 7, 2012 | 07:07 AM
jbpnoman's Avatar
A second set of hands is always a nice thing to have. This might sound extremely stupid, basic, and 101, but have you verified your firing order is correct?
Old Sep 7, 2012 | 07:11 AM
purgat0ry's Avatar
Indeed, first thing I checked actually; I'll double check it again tonight
Old Sep 7, 2012 | 01:16 PM
95civicproject's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
CHECK THE FAQ at the top of the 92-0000 forum
FUEL COMPRESSION SPARK TIMING
start there ^ ^^^^^^^^^
Old Sep 7, 2012 | 02:38 PM
purgat0ry's Avatar
Distributor firing order in my Haynes manual is ... wrong to say the least!
Adjused all of that crap and all is good and pure in the world, she lives!
Now to just figure out if I have any leaks at all :D
MitchHamilton
15
Oct 25, 2016 05:00 AM
Millerandrew
12
Mar 16, 2015 12:37 AM
sunnyutahsky
Aug 10, 2013 06:32 PM
infinkc
Feb 21, 2013 01:32 PM
dc2doi
Jan 6, 2008 01:43 PM
