Civic or Integra Type R Cams?
Old Oct 16, 2002 | 04:45 PM
XzzYzzX's Avatar
Default Civic or Integra Type R Cams?
I have a 95 GSR in my 91 Crx Si I am trying to find out which cams to put in my motor? Should i go with an Integra type r intake cam and leave the other stock or someone told me to go with a civic type r intake cam an a integra type r exhaust cam. If you have any suggestions it would help. Thanks
Old Oct 16, 2002 | 04:50 PM
piatl7il77's Avatar
Default Re: Civic or Integra Type R Cams? (XzzYzzX)
ctr intake cam and itr exhaust cam. ctr is the more aggresive cam. Both have the same hieght on the exhaust side, so just go with the itr for the exhaust since it is cheaper
Old Oct 16, 2002 | 10:49 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Civic or Integra Type R Cams? (piatl7il77)
ctr is more agressive on the intake side on cams before the 00-01 spec..so basically that means 00-01 itr/ctr cams are the same
Old Oct 16, 2002 | 11:04 PM
B2FiNiTY's Avatar
Default Re: Civic or Integra Type R Cams? (CiRcUiTsi)
Just get 00-01 USDM ITR cams. Same as CTR but much cheaper.
Old Oct 17, 2002 | 12:21 AM
iH8RICERZ's Avatar
ditto....i did ctr intake cam in my 94 gsr..... felt a lil more power in the top end, but was hoping for a lil bit more uummmpphh, so if you cant do ctr int and itr exh...then just get both itr, or both ctr...
Old Oct 17, 2002 | 06:12 AM
VTC_CiViC's Avatar
Default Re: Civic or Integra Type R Cams? (iH8RICERZ)
'00 spec ITR's aren't exactly the same, I think they have a shorter duration (3 degrees is it?) as per the ITR guys, but it's alot closer to the CTR than the 97-98 ITR cams.
Old Oct 17, 2002 | 10:23 AM
94gsr4dr's Avatar
When you installed your ctr intake cam, did you change the vtec engagement point, cause that could cause a bog in the midrange, vtec should be set around 5 instead of 4400, thought i would ask.
Old Oct 17, 2002 | 11:03 AM
neo1z's Avatar
Default Re: Civic or Integra Type R Cams? (94gsr4dr)
they difference between all of the R cams are pretty much negligable though my friend --
Old Oct 17, 2002 | 11:04 AM
Dirty GS-R's Avatar
New User
Default Re: Civic or Integra Type R Cams? (VTC_boost-less_CiViC)
the '00 and '01 ITR cams are the same as CTR cams. '97 and '98 have 3 degrees less duration.
Old Oct 17, 2002 | 01:07 PM
VTC_CiViC's Avatar
Default Re: Civic or Integra Type R Cams? (Dirty GS-R)
Really? I got that from the ITR forum a while back when searching for cams for the Teg.. thanks
Ra GS-R
Aug 10, 2007 03:50 PM
honda06si
Aug 29, 2004 10:54 AM
madhatch
Jun 23, 2003 10:37 AM
quik2kSi
Jul 27, 2002 09:39 AM
-Darren-
Apr 8, 2002 11:58 AM
