Intercooler piping help needed
Old Sep 4, 2012 | 07:03 PM
Toanz's Avatar
Default Intercooler piping help needed
Hey guys
Just trying to figure out how to route the hot side intercooler piping. Having issues picturing
how to do this. Stuck on this last piece and could use some points.
I'm thinking of doing a 90 degree bend downwards and going under the front radiator
support.
Let me know what you guys think.
thanks
Old Sep 4, 2012 | 07:31 PM
90blackcrx's Avatar
Default Re: Intercooler piping help needed
If you wanna drop the pipe that low, either go under the support or the fluid reservoir, I personally would just remove the fluid reservoir and go threw that way.
Old Sep 4, 2012 | 07:53 PM
RaceShopDepot's Avatar
What is the set up may I ask?
Old Sep 4, 2012 | 08:02 PM
Toanz's Avatar
yea, that seems like the easiest route to take. I'd hate to get rid of the fluid reservoir.
But i guess you gotta loose a little to gain a little lol
Old Sep 4, 2012 | 08:03 PM
Toanz's Avatar
5th gen prelude
- spoolin quick4ac manifold
- silver surfer turbo
- built engine
cant remember that exact intercooler size, i wish i made proper measurements before buying.
Old Sep 4, 2012 | 08:06 PM
wantboost's Avatar
Who is Mr Robot?
unless you go backdoor that windshield washer tank has to go, doesn't matter which honda you have
the hot pipe would hang too low if you ran it under the tank
Old Sep 5, 2012 | 07:55 AM
that-guy's Avatar
not too familiar with that chassis, but can't you just notch a 3" hole next to that large opening in order to get the pipe in there nice and tight, while also keeping the washer res?
Old Sep 5, 2012 | 09:29 AM
SovXietday's Avatar
This is a good example of where it would be nice to have a backdoor setup.
Old Sep 5, 2012 | 10:02 PM
90blackcrx's Avatar
The a/c stuff would most likely get in the way and it looks like it has a full size radiator.
I'd recommend this option for a 5th gen lude
Old Sep 6, 2012 | 05:35 AM
SovXietday's Avatar
I think it does as well, but if you trim the rad support a bit and place the backdoor high on the intercooler there is definitely room for 2.5" piping to fit through there. Of course this is considering he can/has access to that type of modification.
Otherwise, yeah, dump the resevoir and have fun.
Old Sep 6, 2012 | 12:52 PM
Vagitarian's Avatar
You can relocate the washer resevoir, they sell some that are quite small and can fit in alot of places, but obviously would need to be filled after you use them a little
I have one on my old cvic and switched it over to the passenger side fenderwell, holds about 750ml
Old Sep 8, 2012 | 12:48 PM
EF9_TryMe's Avatar
Washer fluid reservoir.
Lol. What's that ?!
93boostludeSi
Apr 18, 2007 03:35 PM
4thgenx42
Mar 28, 2007 07:01 PM
forcedaccord95
Welding / Fabrication
May 13, 2005 08:19 PM
Integra_Boi
Oct 8, 2004 08:43 AM
