homemade icebox
Old Oct 16, 2002 | 03:37 PM
MotorMilitia LS
Guest
Posts: n/a
Default homemade icebox
i need to put the last finishing touches on my homemade icebox. bought a cheap *** intake pipe at autozone, connected to a comptech air filter, took out the resonator but now i need to down pipe under the stock box. anyone else here have one? i have no idea where to get a pipe that would connect to the bottom of the stock air box that leads to the turn signal. i want to get 3" piping which is bigger compared to comptech's 2.5" (correct me if im wrong.) any of you guys have any ideas where i can get a pipe that would go from the bottom of the airbox to the turn signal and how can i connect it to the bottom of the airbox. the hole underneath the airbox isnt totally circular, its more like a rectangle with rounded sides, i have no idea how to get a pipe to connect to that. please help, thanks.
Old Oct 16, 2002 | 04:55 PM
ragejed's Avatar
Default Re: homemade icebox (MotorMilitia LS)
Tried the Home Depot Market yet?
Old Oct 16, 2002 | 05:27 PM
TimoneX's Avatar
New User
Default Re: homemade icebox (ragejed)
I used 4" flex tubing(dryer hose) for the time being. I ran the tubing to a funnel shaped gizmo I constructed out of aluminum and mounted behind the right side intake hole in my WW air dam. I also put some black mesh screen over it. Looks good(you can't see any of the dryer hose) works perfectly.
Old Oct 16, 2002 | 05:39 PM
-BlueGSR-'s Avatar
Default Re: homemade icebox (TimoneX)
I also used some 3" dryer hose or aluminum duct hose..whatever you want to call it....molded it to fit in the airbox hole and ran it to the turn signal area...because its flexible u can shape it any way u want...so it shouldnt be hard to put it through the airbox hole....
Old Oct 16, 2002 | 09:33 PM
StickyWhiteRice's Avatar
yeah the home depot trick works perfectly, just get 3inch pvc n sqaush it to fit the .."oval" is the word i believe you were looking for and a coupla 90 degree elbows and yer set. no problem n cheap as hell do a search for more info.
Old Oct 16, 2002 | 09:45 PM
TimoneX's Avatar
New User
Default Re: homemade icebox (StickyWhiteRice)
lol
I can just see someone reading that post and trying to squash PVC tubing into an oval. That stuff is tough! LMAO
Old Oct 16, 2002 | 09:48 PM
BSQ's Avatar
BSQ
You can go to my webpage at http://www.geocities.com/bretq/DIY_Icebox_CAI.html for complete step-by-step instructions (with photos and materials list) for making your own DIY "Icebox". Once painted and installed it looks and performs just like the Comptech Icebox, but at a fraction of the cost.
Let me know if you have any questions.
Old Oct 16, 2002 | 09:52 PM
BSQ's Avatar
BSQ
Not if you use the 3" thin-walled PVC. It is thinner and pliable when compared to regular PVC. Just an FYI, Home Depot and Lowes DO NOT carry 3" thin-walled PVC.
Old Oct 16, 2002 | 09:56 PM
TimoneX's Avatar
New User
Default Re: homemade icebox (BSQ)
Hey! Thanx allot Bret. I was having fun with that too.
Never seen the wimpy stuff. The dryer hose has done the trick for me, but it is rather flimsy stuff.
Old Oct 16, 2002 | 10:32 PM
Patron's Avatar
bret, the website is temporarily out of service
Old Oct 16, 2002 | 11:26 PM
actually the home depot by my house does carry 3" thinwalled pvc and it worked perfectly. guess they're not all the same.
Old Oct 16, 2002 | 11:41 PM
stnwag0n's Avatar
cut the black tube off the resonator and use taht to connect to the bottom of the stock air box. it angles towards the turn signal, you might want to extend it, but it will do the job. mine is doing fine without an extension.
Old Oct 17, 2002 | 12:23 AM
MotorMilitia LS
Guest
Posts: n/a
Default Re: homemade icebox (turb0accrd)
yea, that was the first things i thought of when i pulled the resonator out. thanks for the replies guys!
Old Oct 17, 2002 | 12:28 AM
BSQ's Avatar
BSQ
Default Re: homemade icebox (ptran13)
Yep ...a lot of people are hitting my website...which is both and . Geocities has something in place which limits the number of hits to their free websites . All that I can suggest it to retry the link periodically. Sorry for the inconvience .
Old Oct 17, 2002 | 01:30 AM
MotorMilitia LS
Guest
Posts: n/a
good job bsq, you do any other DIY projects?
Old Oct 17, 2002 | 02:04 AM
BSQ's Avatar
BSQ
As a matter of fact...yes.
= Type-R rear swaybar - http://www.geocities.com/bretq/swaybar_install.html
= Oil catch can - http://www.geocities.com/bretq/DIY_O...tructions.html
= K&N RU-2820 air filter in stock airbox - http://www.geocities.com/bretq/kn2820_airfilter.html
= painted valve cover (nearly identical to the Type-R valve cover) - http://www.geocities.com/bretq/Valve...tructions.html
= custom trunk brace (similiar to Type-R rear trunk brace) - coming soon / see https://honda-tech.com/zerothread?id=291430 for some details
[Modified by BSQ, 7:09 AM 10/17/2002]
Old Oct 17, 2002 | 02:20 PM
MotorMilitia LS
Guest
Posts: n/a
thnx
Old Oct 17, 2002 | 04:02 PM
LillDragun's Avatar
thin wall
schedule 40 pvc piping
where can i find the thin wall pvc???
Old Oct 17, 2002 | 10:37 PM
BSQ's Avatar
BSQ
Default Re: homemade icebox (LillDragun)
Someone mentioned Ace Hardware to me. I haven't checked Ace Hardware, so I cannot confirm whether they have it or not. I buy mine at a Do it Best hardware store.
JDMkidGSR
Oct 10, 2005 07:49 AM
cbmprelude
Mar 23, 2004 11:34 AM
LFA Squad :: iTO
Dec 8, 2003 03:40 PM
R rated
Nov 14, 2002 05:23 PM
