procedure for removing oil pan
Old Oct 16, 2002 | 03:24 PM
crxtremes's Avatar
Default procedure for removing oil pan
i have a 90 crx dx. the oil pan gasket is leaking. what do i have to take off in order to get to the oil pan to take it off, to put a new gasket on it. thanks
Old Oct 16, 2002 | 03:26 PM
Booger's_Rex's Avatar
Default Re: procedure for removing oil pan (crxtremes)
a few 10mm bolts on the oil pan and the cover between the tranny and oil pan. then it should come right off.
Old Oct 16, 2002 | 03:32 PM
crxtremes's Avatar
Default Re: procedure for removing oil pan (Booger's_Rex)
so i dont have to take off any part of the exhaust to get to it?
Old Oct 16, 2002 | 03:45 PM
i had my header off at the time, but i think it may need to come off to get the pan off i may be wrong.
Old Oct 16, 2002 | 03:52 PM
MADEINIRAQ's Avatar
i would say remove anything prohibiting you from removing the oil pan
Old Oct 16, 2002 | 04:09 PM
RallySportCivic's Avatar
Default Re: procedure for removing oil pan (madeiniraq)
Yes you do have to take off your manifold and downpipe, I am not sure if you MUST do this, but it gives you WAY more room, and its not that hard to take it off, I changed my gasket in about 2 hours or so.
Old Oct 16, 2002 | 04:15 PM
EL Vap133's Avatar
I have to do the same thing with my CRX but it has a B16 so I know it's gonna be more of a bitch...
Old Oct 17, 2002 | 08:07 AM
phoboyjimmy's Avatar
Default Re: procedure for removing oil pan (RallySportCivic)
I changed my oil pan gasket when I did my MPFI swap. You don't have to take off the exhaust manifold or the downpipe. However, if you do take it off, then there will be more room for you to remove the bolts near the downpipe. One thing that you do have to take off is the shim guard for the flywheel. Be careful when you remove this, because you can get oil on the flywheel.
Other than that, it was pretty straight forward. Word of advice...get a MANUAL !
You'll be FUCT if you can't remember where everything goes.
Old Oct 17, 2002 | 08:10 AM
EL Vap133's Avatar
Default Re: procedure for removing oil pan (phoboyjimmy)
LOL!! Thanks for the advice Jimmy...
Old Oct 17, 2002 | 08:39 AM
spettinger's Avatar
Default Re: procedure for removing oil pan (Vap133)
if you are running the stock header from the B16, just unbolt the downpipe. then you have access to the oil pan. if you have a header, then it looks like you need to drop your front crossmember, disconnect the radius arms that go to the control arms, then undo the header, finally reaching the oil pan. cheers.
Old Oct 17, 2002 | 09:56 AM
NikoZai's Avatar
Default Re: procedure for removing oil pan (get a manual!)
Manual is on my sig download, print what you need and get to work.
Old Oct 17, 2002 | 01:19 PM
You welcome DANNY BOY!
jdmwojo
12
Feb 1, 2010 08:34 PM
stets
10
Mar 2, 2008 04:12 PM
hondaracing1
11
Mar 18, 2004 04:01 PM
MR. ARIZONA
Sep 3, 2003 05:04 PM
swlabhot
Aug 21, 2003 04:38 AM
