timingbelt issue b series
Old Aug 31, 2012 | 11:47 AM
skaraider's Avatar
Default timingbelt issue b series
94 civic with a b17 block
So i have a few questions
1.which direction do i tighen? clockwise or counter?
2. which side to i put on first Intake or exhaust?
I tried tightening and it always slips off one cam.. I was looking around and i can't seem to find this anywhere
Yes I know where TDC is and its set, I just need the following either explained to me or in a picture..
Thanks in advance
Old Aug 31, 2012 | 11:49 AM
kyden's Avatar
Default Re: timingbelt issue b series
download the helms manual, it is all explained thoroughly in there.
Old Aug 31, 2012 | 04:03 PM
skaraider's Avatar
Why is there even a forum if your going to say that, i should just reply to that for anyone with a problem. I know it's in the book... I'm do my posting from my phone, so it doesn't do me any good to download it on my phone.
Old Sep 1, 2012 | 06:03 AM
skaraider's Avatar
1) Remove the cylinder head cover.
2) Set the No. 1 piston at TDC
3) Rotate the crankshaft five to six revolutions to set the belt.
4) Set the No. 1 piston at TDC
5) Loosen the adjusting bolt 1/2 turn (180deg) only.
6) Rotate the crankshaft counterclockwise 3-teeth on the camshaft pulley.
7) Tighten the adjusting bolt to the specified torque.
8) After adjusting, retorque the crankshaft pulley bolt to 177Nm.
I believe this is correct, please let me know if its not.
Old Sep 1, 2012 | 06:37 AM
ef92b's Avatar
^ Correct.
Old Sep 1, 2012 | 06:59 AM
skaraider's Avatar
ok, Thanks :D
RIP V8s
Nov 12, 2007 11:28 PM
smileycvc
Apr 1, 2007 01:14 AM
the.hamburglar
Sep 27, 2005 03:26 AM
LSEGHATCH
21
Jul 27, 2005 07:27 AM
