4port solenoid boost control issue ?
Old Aug 30, 2012 | 05:21 AM
Lyle_57IAL's Avatar
Default 4port solenoid boost control issue ?
Hey guys.
Own a d16z6. Runnning a 38mm tial wastegate with a 12psi spring. Useing a turbosmart 4 port solenoid to control boost to 24psi. Was tuned with 30hz freq and 35duty to achieve this.
After this was tuned and stale on the dyno I took to the street to setup the boost by gear and was Useing duty cycle specific. Due to not having a enough span with the solenoid on 30hz I changed to 55hz with a new duty cycle of 44% to achieve the same max boost pressure (24psi). I then Set all the duty cycles in the table and got the car responding exacly the way I wanted.
1st - gate pressure
2nd - 15psi
3rd - 19psi
4th - 24psi
5th - 24psi
Now. After I got this set I started playing with the quick spool feature - this is where things started going pear shaped. (car started responding different every time I gave it a hit). Hence I removed the quick spool all together.
Now however my car does not respond to the gear based duty cycles and simply hits. Y boost cut protection in every gear ! I change back to a fixed duty cycles and set it at 0% and I'm still hitting my boost cut (25psi)
I have confirmed the solenoid turns on and off my cycling the power to it and hearing it click. The only way to stop the solenoid from free boosting my car with no control is to change its operational state to normally closed (instead of normally open). This does get my gate pressure however then it won't respond to any duty cycle settings !?!?
Is these something I am missing or could try to isolate this problem and repair it ?! Could I have friend this solenoid even though it still clicks with power?
Any help would be Awsome
Old Aug 30, 2012 | 05:30 AM
Muckman's Avatar
Moderator in Chief
Default Re: 4port solenoid boost control issue ?
Are you sure your duty is not inverted? I dont see a rise in boost until 50% duty. I suspect your problem lies mostly with the frequency. Try lower around 20-30hz and retest.
Old Aug 30, 2012 | 05:50 AM
Turbo-LS's Avatar
Yeah i was playing with the quick spool at the track two weeks ago. My boost was all over the map and spiking really bad and going up and down from 15 to 25 psi. Turned that crap right off. I stuck with duty cycle and put 99% in the lower rpm acts just like the quick spool should and then dial it down to the desired duty cycle as the boost ramps up in the higher rpm range.
Sounds like the OP might have a bad vacuum line also if your turning it off and still hitting boost cut then its not getting a boost source to the bottom or the valve is stuck and its getting full boost to the top
Old Aug 30, 2012 | 01:16 PM
DA 4 Lyfe's Avatar
I had the same problem with that 4 port bullshit. Honestly, I messed with it at the track for a few months every Wednesday and STILL didnt fix my issue. I said the hell with it and went back to a 3 port and it holds ALOT better and no more worrying about duty cycle once I got re-tuned. Just my .02 on this matter
prahaian
Jan 8, 2014 11:46 AM
kmaz93da
Jun 2, 2010 06:24 PM
mozzandherb
Apr 14, 2010 10:09 AM
JDM97R
Mar 4, 2010 04:43 AM
JDM97R
Mar 3, 2010 06:19 AM
