Big hep please no vtec
Old Aug 29, 2012 | 09:34 AM
eddysmith2000's Avatar
Default Big hep please no vtec
big hello from the uk, having a little trouble with my b20 vtec basically it's not working, run lots of tests manually opened the solenoid by using 12voly supply checked it opens but still no vtec... It's a b20b3 blocks we are picking up our oil feed from the oil pressure switch not a take off plate, could this be the problem? Or do u get the same pressure as u do from a take off...
Old Aug 29, 2012 | 11:28 AM
civickiller's Avatar
Default Re: Big hep please no vtec
i think its the Vtec oil pressure sensor. mine was faulty so i put my vtec on a switch until i tuned it eleminating the sensor
Old Aug 29, 2012 | 02:31 PM
DraginX's Avatar
Is this a new build or old, basically has it ran and worked before?
Do you have any codes?
Did you verify the wiring is good?
Does your vss work?
Did you block the passage in the bottom of the head?
Is the o-ring in the head below the middle cam cap?
RinzEG6
Oct 14, 2014 03:34 AM
DDream
Sep 20, 2012 05:57 AM
frokido
Feb 20, 2011 05:13 PM
jdm-as-f@$k
18
Jul 10, 2010 09:11 PM
mister2racer
Jun 26, 2005 07:13 PM
