air leak sound
Old Aug 28, 2012 | 06:47 PM
93lsv_turbo's Avatar
Default air leak sound
ive checked all over the place and i cant find where its coming from but its a loud air sound. i mean louder then the engine. i have prefect vac and no hesitation and boost is solid at 7 pounds. im so lost
Old Aug 28, 2012 | 06:49 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: air leak sound
is it only under boost? turbos get loud and sound like a giant air leak/vacuum cleaner.
if you aren't having any trouble with boost issues (lower than 7) or crappy vacuum/idle then that's probably what you're hearing
Old Aug 29, 2012 | 06:18 AM
No its at idle, and when I shut the car off I can hear the noise fade and the engine stops moving. I know the difference between turbo spool and this noise.
I've tried spraying carb cleaner around the area of the noise and nothing changes. Steady vac/boost good fuel pressure no hesitation but a horrible noise
Old Aug 29, 2012 | 06:19 AM
Old Aug 29, 2012 | 09:13 AM
wantboost's Avatar
Who is Mr Robot?
have you checked your blow off valve? if its adjusted too loose they stay open at idle and make a hissing/suction noise
Old Aug 29, 2012 | 09:31 AM
Yes I've checked it. The noise is coming from the drive side of the enigne bay. Around the drives side of the fuel rail/fuel pressure regulator
Old Aug 29, 2012 | 09:38 AM
wantboost's Avatar
Who is Mr Robot?
brake booster?
Old Aug 29, 2012 | 10:41 AM
It very well could be but idk how to check it
EsQueue
Jun 19, 2005 08:06 AM
asianspeed
Mar 4, 2003 06:53 AM
hawjboi
Jun 28, 2002 07:43 PM
shamoo
Nov 20, 2001 07:32 AM
quikrpm'z
Jul 9, 2001 03:28 PM
