Radiator fan just stopped?
What I know:
Amazingly I caught the gauge heading towards H before it over heated.
I turned the heater to high and to Hot and watched it come back down.
I checked my fluid in the reservoir and it was that same nice shade of green.
Too hot to check the radiator. Radiator is recent install from dealer.
Fan spins freely but does not come on at all.
What I plan to check:
Found the fuse while parked at the gas station but it was too small, mini fuse, to check. Will check that out when I get home, but from above, it didnt look burnt.
Doesnt the 96 have obdii? I didnt get a CEL if its the sensor and no CEL now.
What I am asking?
Any one have anything else that I should check? I really appreciate it.
Rick
What I am asking?
Rick
question 1. I think the connector is in between the radiator and the reservoir bottle at the top. Correct?
Question 2. Where is the sensor located on a SOHC 1.6L?
https://honda-tech.com/attachment.ph...1&d=1303077012 <=--- i forgot what this little sensor was called, but basically it turns on the fan. If the fan works when you conect it to the battery then this might be your problem.
E JAY 1
Mar 5, 2008 09:17 PM
Red_ED8
Feb 13, 2008 10:35 AM
ahemming06
Apr 15, 2007 05:12 PM
Nameless Warrior
Dec 9, 2006 03:44 PM
