Vac Manifold to PCV port
Old Aug 27, 2012 | 08:02 PM
roc0487's Avatar
Default Vac Manifold to PCV port
What's up?
Was curious about this setup, in theory it should work fine. I'm about to boost and I plan to gut pcv valve and run a line to catch can and then from catch can to intake pipe pre-turbo. Instead of capping the pcv port on IM, I was going to run a vacuum manifold feed to this port instead of tapping into vac source for brake booster. I want to run bov and boost gauge on this vacuum vs t'ing into fpr. Anyone done this?
Thanks
Old Aug 27, 2012 | 08:46 PM
crvtectim's Avatar
Default Re: Vac Manifold to PCV port
You can do that, but it's recommended to use the booster port due to its increased size.
Old Aug 27, 2012 | 08:53 PM
roc0487's Avatar
Thanks man, I was thinking of either doing a vac mani or individual vac sources but don't want a bunch of tee's in the bay. I only need 2 so it wouldn't be too bad I guess, but word of mouth is that the bov needs it's own. Also, trying to stay away from fpr vacuum, if something leaks and it leans out, that's no good. lol
Old Aug 27, 2012 | 08:55 PM
roc0487's Avatar
I feel like a dipshit, why not run a tee to the pcv port and have the bov and gauge share it? Versus running a block just for 2 parts, seems legit.
Old Aug 28, 2012 | 07:06 AM
crvtectim's Avatar
Sure, but def stay away from any tees in the fpr's line.
EastCoastRust
Aug 11, 2014 11:06 AM
mikej94civex
Apr 10, 2010 09:09 AM
superslow-oto
Nov 6, 2007 02:42 PM
superslow-oto
Oct 30, 2007 11:43 AM
dumas07
Apr 9, 2007 02:04 AM
