Oil pressure readings
Old Aug 27, 2012 | 02:01 PM
ninjaturtleEG's Avatar
Default Oil pressure readings
Just installed an eletrical oil pressure gauge. I currently don't remember what the cold start pressure reading is but it was high around 80psi
Warm idle - 30psi
1800rpm - 80psi
2200rpm - 90 psi
3000-4000 rpm - stays at 90 psi
4000rpm+ - from here very slowly climbs up but havent got a chance to go above 4500rpm yet.
So as you can see, from idle when i start to accelerate, barely touching the throttle the pressure reading spikes up to 80psi at 1800rpm. It reaches 90 psi before 2500rpm and stays there for awhile. Is this a normal reading?
Old Aug 27, 2012 | 03:26 PM
MonkeyMagic's Avatar
Default Re: Oil pressure readings
what brand gauge?
Old Aug 27, 2012 | 03:33 PM
It is a prosport gauge. Just seems kind of weird that pressure goes from 30-80psi in about 1000 rpm.
Old Aug 27, 2012 | 04:47 PM
grumblemarc's Avatar
The Grumpiest
Normal.
Old Aug 28, 2012 | 10:50 AM
todahead's Avatar
mine with prosport gauge too and oem purflux oil filter.
idle 22psi
2000rpm 62psi
3000rpm 72psi
curtie94
Feb 12, 2012 12:23 PM
es_squared
May 1, 2009 11:14 PM
Bac91Da
Feb 10, 2008 05:25 PM
soontobeboost
Jan 6, 2007 06:22 AM
TurbodTegSfaria
Oct 6, 2006 10:35 AM
