A/C turned warm - 1998 Civic
Old Aug 24, 2012 | 02:25 PM
Rick1t's Avatar
Default A/C turned warm - 1998 Civic
I have a just broken in (282K miles) civic. This summer when it has been 85-90 or higher....my A/C belt would squeal every once in a while....fairly rhythmically as I drive....today the A/C turned warm......I could smell what seemed like asbestos from brakes (wheel) I was on the freeway........I cannot be certain it was from my car....but it would be a strange coincident......When I check for Freon....the gauge stated I was why over pressure.
Any ideas on where to start? The compressor appears to start when I turn on the A/C.
Thanks
Rick
Old Aug 24, 2012 | 04:39 PM
Rick1t's Avatar
Default Re: A/C 1998 Civic
Anyone have any ideas........? Help
Old Aug 24, 2012 | 04:44 PM
Former User's Avatar
Have you done any work on the A/C system?
Does the condenser fan run? Is the condenser clogged with debris?
Old Aug 24, 2012 | 05:51 PM
Rick1t's Avatar
Default Re: A/C turned warm - 1998 Civic
early summer it was a little low on freon......so I added some.....when I turn on the ac the compressor kicks in....I do not think the fan comes on hummmmmm. I hate to sound dumb......does the fan always engage when the ac is turned on?
Thanks for the feedback
Rick
Old Aug 24, 2012 | 05:53 PM
The fan should run whenever the compressor clutch is engaged
Old Apr 14, 2013 | 05:52 PM
Rick1t's Avatar
Ok....its starting to get warmer.....I have determined I need a new Compressor........is it ok to change it out alone or do I need to replace the Dryer and other misc items?
Thanks
Rick
Old Apr 14, 2013 | 06:16 PM
goldsy's Avatar
You should replace the drier whenever the pressure is let out of the A/C system because moisture can get in there, cause corrosion and before you know it, you're replacing the compressor again.
Once you replace the parts, take it to an A/C shop so they can vacuum out the system, check it for leaks and recharge it for you.
Old Apr 14, 2013 | 06:30 PM
Rick1t's Avatar
Thanks for the quick reply....change both the Compressor and Drier......got it......the old girl has 300400 miles I'm hoping to get 400K......
ls1formula98
Jun 12, 2016 08:57 PM
geribair
Jun 7, 2014 11:18 AM
94LS_allmota
Jul 24, 2009 06:06 PM
EJ8 GSR-T
Aug 3, 2007 04:37 AM
TrueUntilDeath.com
Feb 27, 2005 10:53 AM
