A/C turned warm - 1998 Civic
I have a just broken in (282K miles) civic. This summer when it has been 85-90 or higher....my A/C belt would squeal every once in a while....fairly rhythmically as I drive....today the A/C turned warm......I could smell what seemed like asbestos from brakes (wheel) I was on the freeway........I cannot be certain it was from my car....but it would be a strange coincident......When I check for Freon....the gauge stated I was why over pressure.
Any ideas on where to start? The compressor appears to start when I turn on the A/C.
Thanks
Rick
Thanks
Rick
Re: A/C turned warm - 1998 Civic
early summer it was a little low on freon......so I added some.....when I turn on the ac the compressor kicks in....I do not think the fan comes on hummmmmm. I hate to sound dumb......does the fan always engage when the ac is turned on?
Thanks for the feedback
Rick
Rick
Ok....its starting to get warmer.....I have determined I need a new Compressor........is it ok to change it out alone or do I need to replace the Dryer and other misc items?
Thanks
Rick
Thanks
Rick
You should replace the drier whenever the pressure is let out of the A/C system because moisture can get in there, cause corrosion and before you know it, you're replacing the compressor again.
Once you replace the parts, take it to an A/C shop so they can vacuum out the system, check it for leaks and recharge it for you.
Thanks for the quick reply....change both the Compressor and Drier......got it......the old girl has 300400 miles I'm hoping to get 400K......
ls1formula98
06-12-2016 08:57 PM
