d16a6 problems: has spark and fuel, but won't run
Old Aug 24, 2012 | 10:56 AM
Glowicki's Avatar
Default d16a6 problems: has spark and fuel, but won't run
I have a 91 crx dx with a d16a6 swap, and it won't run. It has spark and fuel, but won't fire. I drove it onto the interstate today to go to school and once i was in fifth gear, the car lost power but was still running, I floored it and it kept slowing down. I went to downshift and as soon as I pushed in the clutch the engine wasn't running. I have no clue what is wrong with it. Within the past year I have put a new battery, alternator, distributor, distributor cap, distributor rotor, and fuel filter. It currently is not throwing any cel codes, every once in a while a code 1 for an o2 sensor will come up, but the cel will not be illuminated. Just wondering what could be wrong.
Old Aug 24, 2012 | 11:06 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: d16a6 problems: has spark and fuel, but won't run
How did you verify that there was spark and fuel? Next I'd check for mechanical timing and compression.
Old Aug 24, 2012 | 12:17 PM
Glowicki's Avatar
I attached a timing light to each plug wire to make sure if there was any current flowing. For fuel, I loosened the special banjo bolt on the fuel filter, then had a friend turn the ignition on, fuel started coming out.
I doubt it is a compression issue, because the car was running just fine when I left.
How would i go about checking the mechanical timing?
Old Aug 24, 2012 | 12:56 PM
Glowicki's Avatar
There is at least fuel to the rail, but i don't know if any is making it into the engine.
Old Aug 24, 2012 | 01:03 PM
DumpdEJ6's Avatar
I like the tuna here
That kinda sounds like a timing issue.
Old Aug 24, 2012 | 01:42 PM
4drEF's Avatar
Keyboard Humorist
Does the fuel pump whirrrr for about 3 seconds when you turn the key to ON?
Since you have a timing light, did you check timing?
That would verify your mechanical timing.
(Be sure you disable the electronic ignition advance before trying to check timing)
Old Aug 24, 2012 | 05:32 PM
Glowicki's Avatar
The fuel pump kicks on when the key is turned to the on position.
How would I check timing without the engine running?
Old Aug 24, 2012 | 05:38 PM
Former User's Avatar
Is spark bright white at all 4 spark plugs?
Will the engine start with starting fluid?
You need to check the mechanical timing (diagram below) not the ignition timing.
If the timing is fine, compression test the cylinders.
Old Aug 24, 2012 | 05:40 PM
Originally Posted by Glowicki
When i replaced my distributor about a month ago I had to advance the timing as far as it would go so the car would run properly. I don't know if this helps or not.
Your timing belt skipped a tooth. Check the mechanical timing. If it's off, then replace the timing belt.
Old Aug 24, 2012 | 05:50 PM
Glowicki's Avatar
Spark in all four cylinders is bright white, it will not start with starting fluid.
My mechanical timing is not lining up just right. I am going to pick up a new timing belt this weekend.
Old Aug 24, 2012 | 05:56 PM
Glowicki's Avatar
Thank you for your help.
Old Aug 26, 2012 | 11:37 AM
Glowicki's Avatar
Well, I replaced the timing belt and set the mechanical timing, but it still won't start.
Old Aug 26, 2012 | 01:01 PM
...compression test the cylinders.
Old Aug 30, 2012 | 02:12 PM
Glowicki's Avatar
Okay, so I broke down and took it to a mechanic. They compression tested the cylinders and said 1,3, and 4 had about 125psi while 2 had 0psi. And they reset the timing. They couldn't get it to run. I honestly don't know what to do.
Old Aug 30, 2012 | 02:16 PM
24TEN's Avatar
PHANTOM MENACE
They seriously don't know what to do?!
Aside from compression being on the low side for #1/3/4 (maybe even below minimum spec?), 0 compression is already a red flag that something internal is damaged or worn to the point of a necessary replacement and/or full rebuild.
Only thing I can think of that would be the ultimate life saver for your situation is that your valves are overtightened and causing the valves to not fully seat, or in #2's case not seat at all and cause 0 compression.
Old Aug 30, 2012 | 05:47 PM
Do a cylinder leak down test to determine where cylinder 2 is losing compression.
Old Sep 3, 2012 | 12:03 PM
Glowicki's Avatar
I did manage to get the car started yesterday. The screw that holds the ignition rotor in backed itself out. I put it back in with locktite and it fired right up.
How would I do a cylinder leak down test?
Old Sep 16, 2012 | 03:07 PM
Glowicki's Avatar
Okay, so I bought a compression test gauge the other day and did a compression test. Compression was fine for cylinders 1 and 4 while 2 and 3 were 15-20psi lower. I started it and it was running on all four.
Old Sep 16, 2012 | 07:23 PM
crvtectim's Avatar
Iirc, 26psi difference is the service limit.
Old Jan 2, 2013 | 08:02 PM
Glowicki's Avatar
I figured out why the car wouldn't run a few months back. I had put a new dizzy, dizzy cap, and new rotor in. The screw which holds the rotor in popped out of the dizzy and was sitting in the dizzy cap. Car runs fine.
91civicwa
Nov 5, 2012 10:07 AM
syvpunk
Jul 29, 2010 04:10 AM
91da_teg
Jan 21, 2009 11:16 PM
biggunnz
Dec 27, 2003 05:39 PM
Tij
Sep 2, 2002 04:49 PM
