PLEASE HELP 2000 CIVIC ENGINE SWAP
I HAVE A 2000 CIVIC OBD2B
Obd2a b18b engine,wire harness and ecu
Obd2b to a harness adapter
Odb2b wire harness
The engine already has harness on it obd2b
Do I need to leave it on or take it off
What elese needs to be changed?
Odb2b wire harness
You can't use the B18's harness. You'll want to use your harness but will have to make some adaptations:
-intake air temp sensor is different, use the one from the civic and put it in your intake arm
-distributor plug is different, you'll need to either use an adapter, swap internals, or cut and solder new plugs on it
BOOSTEd2
13
Mar 28, 2011 04:56 PM
TwoKSiR
Dec 18, 2008 10:28 AM
EF7
Sep 25, 2006 09:06 AM
