93' idle rough
Old Aug 23, 2012 | 07:51 AM
ezgo123's Avatar
Icon3 93' idle rough
hey guys, i got a 1993 honda accord lx with the 2.2l and when i start it, it runs alright, but after a minute of idle it starts to get a little lower and is really rough. driving down the road its fine and evens out, its just on idle its pretty bad. also, sometimes it doesnt start, i am assuming its the main relay, would that make it run bad if the relay was faulty?
thanks!
Old Aug 23, 2012 | 02:12 PM
Newtothegame23's Avatar
Default Re: 93' idle rough
Try the idle position sensor
What's it idling? Anything from 600 to 900 is a good idle
Old Aug 23, 2012 | 08:37 PM
ezgo123's Avatar
its barely idling, maybe a few hundred, and it shakes. but other than the idle it runs fine down the road with no surges or anything...any ideas?
thanks guys
Old Aug 28, 2012 | 06:15 PM
Go to YouTube put in Honda idle problem under ericthecarguy that should help. He's the best when it comes to Hondas.
Old Aug 29, 2012 | 08:14 AM
G24's Avatar
G24
Maybe you could try taking off the breather and clean the throttle body. It could be caked up with dirt if you have never cleaned it before. Whenever my idle gets rough I clean it and it goes back to normal. Could also be a vacuum line that's not connected properly. Ever have any stalls when stopping?
Old Aug 29, 2012 | 08:56 AM
StreetsideStig's Avatar
Main relay is a good first guess. But that tends to cut out pretty erratically, whether you're up to speed or not.
Old Aug 29, 2012 | 06:34 PM
ThaHondaMan's Avatar
it could possibly be the throttle positioning sensor.
Old Aug 29, 2012 | 10:38 PM
holmesnmanny's Avatar
start here....
https://honda-tech.com/zerothread/1844067
james007
Apr 30, 2010 04:26 PM
DC2*Integra
Sep 20, 2005 12:51 PM
SilverSellout
12
Feb 27, 2004 12:48 PM
killa_lude
Aug 16, 2003 08:33 AM
Pele
Feb 9, 2003 01:01 AM
