98 civic coupe lsv swap harness question
Old Aug 23, 2012 | 05:35 AM
Lou845's Avatar
Default 98 civic coupe lsv swap harness question
I recently dropped a lsv motor in my 98 civic ex coupe, the car was auto converted to 5 speed and my old harness was a hack job so I am using the one that came with my new motor, it's a b18b1 block with a gsr head and a type r tranny, I put the motor in and have the harness pretty much plugged up, only issue I have is on driver side behind shock tower there are 2 clips coming from the fire wall, the new harness only has 1 of the 2. The one it doesn't have is a clip with I believe 8 slots but only 4 pins in it. Does any one know what that clip is to ? I'm assuming I def need it plugged in, I really don't want to use my old haness since it was put together terribly ( obd1 injector clips wired on, wires cut thought the harness etc) any help would be appreciated
Old Aug 23, 2012 | 06:12 AM
jbpnoman's Avatar
Default Re: 98 civic coupe lsv swap harness question
Post pictures, or at least wire colors.
Old Aug 23, 2012 | 06:57 AM
kyden's Avatar
you have to use a 96-98 harness. you can't use an integra harness.
Old Aug 23, 2012 | 07:26 AM
Lou845's Avatar
I just fount out the harness is out of a 99 coupe, there is a change in haness between 98 and 99 correct ? If so is there any way to use the 99 harness with my car ?
Old Aug 23, 2012 | 07:57 AM
HondaPartsHero's Avatar
Technical Hero
No
97accord_R
Mar 19, 2009 03:47 AM
SwapedEX
Aug 7, 2006 07:51 PM
SONIC BOOM
Feb 5, 2006 04:19 PM
Lucky-R
Apr 21, 2005 08:27 PM
