MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
Old Aug 21, 2012 | 05:09 PM
Javao007's Avatar
Icon6 MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
I BOUGHT THIS CAR FROM A FRIEND BUT I WAS DRIVING TO WORK AND A WATER HOST WAS LEAKING AND MY CAR IS OVERHEATING . I CHANGE THE WATER HOST BUT NOW I HAVE AN OIL LEAK FROM THE HEAD . MY ENGINE STARTER DOESN'T WORK. I HAVE TO HIT IT FOR TURN ON THE ENGINE . I WANT UPGRADE MY REGULAR ALTERNATOR FORM 90 AMP > 130 AMP I DON'T KNOW IF I WILL DAMAGE THE ECU??.. AND WHAT OTHERs UPGRADE I CAN DO BEFORE I CHANGE THE HEAD GASKET???
AND THE MOST IMPORTANTE .....
HOW CAN I CHANGE THE HEAD GASKET AND WHAT KIND OF HEAD I HAVE ???
PICTURES:29
I will appreciate you help!! thanks
Old Aug 21, 2012 | 05:31 PM
Javao007's Avatar
Icon6 Re: MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
PICTURES:https://plus.google.com/u/0/photos/1...09092897?hl=en 29 photos
Old Aug 21, 2012 | 05:38 PM
Javao007's Avatar
Icon2 Re: MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
ANY IDEAS???
Old Aug 21, 2012 | 06:10 PM
jbpnoman's Avatar
Default Re: MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
The block and head are both stamped with their codes. Read the code. We can't magically tell you what kind of head you have.
Also, there's a lot of knockoff parts under that hood.
Old Aug 21, 2012 | 06:55 PM
Javao007's Avatar
where are the code located?
Old Aug 21, 2012 | 07:14 PM
Blacknight117's Avatar
Looks like a d16y8?? But the stamp will be on the right of the header..
Old Aug 21, 2012 | 07:16 PM
jbpnoman's Avatar
Originally Posted by D-Man
...its[sic] located above the exhaust ports of Cyl #2 and #3 or near that location...
Old Aug 21, 2012 | 07:23 PM
doood's Avatar
been there done that
where's the mugen?
Old Aug 21, 2012 | 07:25 PM
The Ebay valve cover, duh lmao
Old Aug 24, 2012 | 05:55 PM
VanDorin91's Avatar
Nice cold air intake. So cheap its not even there.
Old Aug 24, 2012 | 08:30 PM
dirty19's Avatar
Ridin Dirty in Cali
Yep looks like a Y8
the code will be on the front of the engine as you are looking at it and will be to the left of the header.
it will look like this...
Old Aug 25, 2012 | 04:13 AM
grumblemarc's Avatar
The Grumpiest
NOT a Y8. Dipstick is in the wrong place.
Old Aug 25, 2012 | 04:51 AM
dirty19's Avatar
Ridin Dirty in Cali
Ur right marc............ I was looking at the intake manifold.
Block will be marked here.
Old Aug 25, 2012 | 04:54 AM
I was looking at the same thing when the op first opened the thread. We won`t really know until the op decides to post again...
Old Aug 25, 2012 | 05:16 AM
nealnanoHX's Avatar
LOL I love the 2 strut bars. Get rid of the Ebay one and keep the OEM one but repaint it black like it should be. Your Mugen VC is a knock off also.
Old Aug 25, 2012 | 05:25 AM
Deetz's Avatar
Crazy Honda Guy
I don't think there are any "real" mugen parts on that car at all. It appears the previous owner took a bottle of black spray paint, and just shot the whole engine bay, over the bolts/mounts, everything except the engine.
To use a beefier alternator should not be an issue, that is what a regulator is for
Old Aug 25, 2012 | 10:27 AM
The Grumpiest
Considering that' a 5th gen engine bay it's probably just an old Z6.
Old Aug 31, 2012 | 05:26 PM
Javao007's Avatar
Post Re: MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
I'm back ... some updates!!
What i need to know?
1-?
2-?
3-?
4-?
5-?What is the next step to take out the engine head???
Old Aug 31, 2012 | 05:32 PM
redm3turbo's Avatar
Java has nice tropical grass.
Old Sep 1, 2012 | 07:38 AM
Javao007's Avatar
Icon4 Re: MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
thanks
Old Sep 1, 2012 | 08:28 AM
habanerored06si's Avatar
You never answered this question. Although I'm pretty sure its a D16Z6 (Although you seem like English is a 2nd language. Where are you from? Engine codes might be different in your country). Unless its some Mini-Me swap.
Why do you need to increase the amps?
Read these threads
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/coolant-reservoir-slowly-filling-up-2325858/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/difficulty-level-diy-replacement-head-gasket-d16z6-2340642/
The Poster b18c5-EH2 has some valid points that talk alot about your situation.
Cliff note: Buy a new engine, because yours has a **** load of problems and D16's are cheap.
Old Sep 1, 2012 | 09:51 AM
Javao007's Avatar
Read these threads
https://honda-tech.com/forums/showthread.php?t=2325858
https://honda-tech.com/forums/showthread.php?t=2340642
yes it's a mini-me swap ..
why i need more amps ? i wanna add: amplifier, hid, custom led light and more things that consumer electricity!
BoorishId
Feb 18, 2009 10:47 AM
josephshark
Paint and Body
Aug 9, 2007 08:21 PM
lsegcoupe
Jul 30, 2006 09:53 AM
delsolofbradenton
13
Apr 2, 2005 09:51 PM
Electrodynamic
22
Jul 20, 2004 07:30 PM
