MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
I BOUGHT THIS CAR FROM A FRIEND BUT I WAS DRIVING TO WORK AND A WATER HOST WAS LEAKING AND MY CAR IS OVERHEATING . I CHANGE THE WATER HOST BUT NOW I HAVE AN OIL LEAK FROM THE HEAD . MY ENGINE STARTER DOESN'T WORK. I HAVE TO HIT IT FOR TURN ON THE ENGINE . I WANT UPGRADE MY REGULAR ALTERNATOR FORM 90 AMP > 130 AMP I DON'T KNOW IF I WILL DAMAGE THE ECU??.. AND WHAT OTHERs UPGRADE I CAN DO BEFORE I CHANGE THE HEAD GASKET???
AND THE MOST IMPORTANTE .....
HOW CAN I CHANGE THE HEAD GASKET AND WHAT KIND OF HEAD I HAVE ???
PICTURES:29
I will appreciate you help!! thanks
PICTURES:29
Re: MUGEN DEL SOL 1993 D15B VTEC BUILD AND UPGRADES!!! SUGGESTION?
PICTURES:https://plus.google.com/u/0/photos/1...09092897?hl=en 29 photos
The block and head are both stamped with their codes. Read the code. We can't magically tell you what kind of head you have.
Also, there's a lot of knockoff parts under that hood.
LOL I love the 2 strut bars. Get rid of the Ebay one and keep the OEM one but repaint it black like it should be. Your Mugen VC is a knock off also.
Crazy Honda Guy
I don't think there are any "real" mugen parts on that car at all. It appears the previous owner took a bottle of black spray paint, and just shot the whole engine bay, over the bolts/mounts, everything except the engine.
To use a beefier alternator should not be an issue, that is what a regulator is for
I'm back ... some updates!!
What i need to know?
1-?
2-?
3-?
4-?
5-?What is the next step to take out the engine head???
1-?
2-?
3-?
4-?
Why do you need to increase the amps?
Read these threads
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/coolant-reservoir-slowly-filling-up-2325858/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/difficulty-level-diy-replacement-head-gasket-d16z6-2340642/
The Poster b18c5-EH2 has some valid points that talk alot about your situation.
Cliff note: Buy a new engine, because yours has a **** load of problems and D16's are cheap.
You never answered this question. Although I'm pretty sure its a D16Z6 (Although you seem like English is a 2nd language. Where are you from? Engine codes might be different in your country). Unless its some Mini-Me swap.
Read these threads
https://honda-tech.com/forums/showthread.php?t=2325858
https://honda-tech.com/forums/showthread.php?t=2340642
Read these threads
why i need more amps ? i wanna add: amplifier, hid, custom led light and more things that consumer electricity!
delsolofbradenton
13
04-02-2005 09:51 PM
