oil feed line and return line...which one do you guys recomment me to buy
Old Oct 16, 2002 | 06:39 AM
C1V1CS1's Avatar
Default oil feed line and return line...which one do you guys recommend me to buy
I'm looking for an oild feed line and an oil return line and some fittings. is there any particular one you guys prefer or recommend to use. also where can i get them?
[Modified by C1V1CS1, 4:02 PM 10/16/2002]
Old Oct 16, 2002 | 07:02 AM
RGAZ's Avatar
New User
Default Re: oil feed line and return line...which one do you guys recomment me to buy (C1V1CS1)
Oil feed line: Recommend Aeroquip steel braid in An4 from http://www.anplumbing.com Oil return line: recommend Aeroquip stell braid in AN10 from same.
If the AN4 is too big in your opinion, use An3 or a restrictor.
Do a search, I am sure there is alot of info already on this.
Randy
Old Oct 16, 2002 | 08:25 AM
mos's Avatar
mos
Default Re: oil feed line and return line...which one do you guys recomment me to buy (RGAZ)
I'm going to be running 1/4" brass barbed fittings with pep boys oil hose and hose clamps. 1/2" for the return line...
Old Oct 16, 2002 | 12:11 PM
underpressure02's Avatar
Default Re: oil feed line and return line...which one do you guys recomment me to buy (mos)
Had the same question the other night. I just bought a hatch with a turbo motor and the oil return line was almost gone. The guy had used coolant hose. I went to a couple of different shops and no one had oil hose only coolant hose. I ended up using hydraulic hose from a forklift. Good to 300 PSI. I figured I would use this until I find a better hose. What do you think?
Old Oct 16, 2002 | 12:23 PM
b18bturbo's Avatar
Default Re: oil feed line and return line...which one do you guys recomment me to buy (underpressure (wtbimp
theres no pressure in the return line so you should be good. If you want give me call i can set you up 2 45 degree swivels -10 weld bung -10 to 1/2 fitting and flange and line for 92.50
jacob4lester
Feb 16, 2010 08:36 PM
stackz
Feb 28, 2008 01:49 PM
Black R
Feb 20, 2005 03:12 PM
Diego Boost
Mar 10, 2003 01:20 PM
