k20a2 runs shitty or not normal...
Old Aug 16, 2012 | 11:21 PM
jesselugs's Avatar
Default k20a2 runs shitty or not normal...
ok sooo it alll started when i took the car out of town, i went out of town got to the lakes my cars 2nd and 4th gear went out soo i took it apart and sent the tranny to get looked at sooo my tranny wasnt bblown.. or anything got my trans back. i put it toghether and then it wouldnt shift into gear so i sent it to get fixed. i needed a new clutch and flywheel and pressure plate w/e. while the engine was in my garage i washed it with a pressurew washer and i know i got water in the cylinders but i blew the cylinders out with a air air compressor. so the engine sat around my garage for about a month with a cover. enough time to dry on its own soo i think. i put the car together and clutch works good. shifts perfect but now my engine feels like its running like ****!
it feels likeee its a missfire or as if it was running on 3 cylinders orrr maybe like not enought gas is going to itt
it just runs like ****... not enought power... it feels boggy but it doesnt shut off it idles a little differrent... like it will sit normal and it will serge up maybe 100 rpms quick and back down every like 10 seconds it just sound different than when it ran normal... maybe a sensor? i did pull on a o2 sensor on the exhaust by accident but it seems fine... so i plugged every sensor on the engine back in the right order.... i labed the spots... everything and its still running like ****... idk
when i give it gasss it seems too be really rough like its going to go or stop go or stop... and im holding the gas at the same spot.... and then after it rolls for a bit it seems to catch..... and gooo then does the same.... and i hit the interstate and i pass 3000 rpms and seems to run a little... smother but still rought when i try to accelerate. idk what it can be.. its a k20a2 running kpro with reflash. 6 speed. in a eg hatch if something thinks they can help. or even read my writing let me know what you think. if i posted it in the wrong spot move it for me idk how... sorry and thanks!
Old Aug 16, 2012 | 11:24 PM
jesselugs's Avatar
Default Re: k20a2 runs shitty or not normal...
it also back fires when i hit the gas to go faster... then i let go of the gas it will back fire... like there is to much fuel going to it orrr idk..
shuiyuan
Nov 14, 2012 04:42 PM
Metalluthier
27
Jul 11, 2006 10:34 AM
Re3irth
Jul 12, 2004 12:23 PM
daveoner
Jun 4, 2004 02:27 AM
Escabar
22
Nov 7, 2003 09:49 AM
