PCV System / Catch Can Setup for 500 HP B18C1 build.
This is a weekend fun car, as well as a normal AutoX/Road Race car.
Alright. Here is my build right now:
B18C1 Benson Sleeved 84mm Block
Carrillo Rods
CP Pistons
Cometic Gasket
B18C1 Head (full port polish)
Skunk 2 Tuner 1 Cam
Supertech Dual Valve Springs
Supertech Titanium Retainers
Buddy Club Cam Gears
GT30 Turbo
2.5" Downpipe and Exhaust
I currently DO have a vented catch can attached to the nipple from the valve cover, and from the PCV valve coming out of the back of the block ( black box ). I am currently running 15psi of boost for my break in tune. I am going to be close to 30psi in a few weeks. But right now, if I stay in boost for an extended period of time, my catch can will fill up and over flow (its a decent size catch can).
I believe that the excess oil is coming from the PCV system not being able handle the excessive boost? Am I correct?
Now, my question is, if I plug the hole where the black box goes in the back of the block, and completely remove the black box all together, and install four (4) -10AN lines from the valve cover to my catch can, would this be a sufficient ventilation system? Or do I still need a line from the back of the block (one of the 14mm hex head bolts) going to my catch can?
I have searched and came up dry, because most people I have found don't run this much boost (or just have not posted, lol)
Thanks in advance for your time!
Carrillo Rods
CP Pistons
Cometic Gasket
Skunk 2 Tuner 1 Cam
GT30 Turbo
15psi for break in? really?
The problem is the PCV valve is tiny. Its doing nothing anyways just replace it with a large barb fitting to your catch can. The stock breather box does a decent job of baffeling the crankcase pressure. I stuffed a giant 3/4" fitting in my breather box to my catch can.
i have the prelude barbed fitting in my CRX and i have a custom Jaz 2qt can. its mounted right behind my Victor X on the firewall. its a tight squeeze but there is almost never any oil in the can. if you mount it high you shouldnt have a problem.. i have 2 lines in the valve cover and 2 at the back of the block. breathers were meant for crank case pressures i would think the block sees the most pressure, but hey 4 lines to your valve cover looks pretty rad lol
i just uploaded this old video to show you how it came out and what it took GL
http://www.youtube.com/watch?v=QqsFt...layer_embedded
