Catch can
Old Oct 3, 2010 | 03:06 PM
93 Eg Couper's Avatar
Default Catch can
Im getting my Turbo D16 tuned tomorrow. Vitara/Eagle and stock head, Y7 block, Z6 vtec head..
Im shooting for 250whp...im driving on 150whp right now with a "half ***" catch can. One line coming off valve cover and another coming off PCV valve(black box obvs still attached) so its getting a bit of ventilation down low...
It is safe to get it tuned like this? At least its venting a bit...ill hook the can up asap removing the black box and getting a valve cover with bungs in it made..
OR. i could removed the black box, stick a bung in the hole and run a line off it to a "make up" can or something...just so the oil doesnt leak on the dyno...
Old Oct 3, 2010 | 03:32 PM
sik96teg's Avatar
Default Re: Catch can
mine is setup similar to yours. I have a line going to the vc and breather box on the back of the block. I drilled out the valve on the pcv. My car seems to be fine been boosted for a few weeks making just over 300hp. Your setup should be fine. For me i like keeping the black box on because it helps block some of the oil from leaving the motor. I havent had to add a drop of oil to my motor.
Old Oct 3, 2010 | 03:45 PM
heavy duty's Avatar
GO AUTOWORKS has a really good kit to do it right take off the black box and put there set up on it. BUT it will do till after the tune.
Old Oct 4, 2010 | 12:26 AM
96_civic_EX's Avatar
http://advancedstreetperformance.com...atcatch_lg.jpg
This is one of the sickest catch cans on the market!!
Its just a pic of the prototype, obviously it will have bungs in it.. custom to you depending on how many bungs you want on it. Also fits odyssey batteries. He sells the batteries in the pic also to go with the catch can if needed.
Old Oct 4, 2010 | 01:24 AM
cleansi's Avatar
OR. i could removed the black box, stick a bung in the hole and run a line off it to a "make up" can or something...just so the oil doesn't leak on the dyno...
you got it! run a line from the bung on the back of the block (remove the box you can get the fitting from honda from a b20 ) and voillllaaa.
unspankable
Nov 4, 2013 02:20 PM
j.packsb
Jan 8, 2010 05:58 AM
efjones9
Apr 20, 2009 09:01 AM
boostedteg4dr
May 12, 2008 01:29 PM
ccivic
Dec 6, 2005 07:29 PM
