Can this head be fixed?
Old Aug 15, 2012 | 10:10 PM
kickadog55's Avatar
Default Can this head be fixed?
I found a deal on a gsr head with a valve that broke. So i been reading alot bout head repair but am wondering if something this bad can be repaired?
Old Aug 15, 2012 | 10:44 PM
eg6 type-R's Avatar
Default Re: Can this head be fixed?
wow! that looks like alot of work for the machine shop.. alot of time and work =$$$$$
Old Aug 15, 2012 | 10:46 PM
kickadog55's Avatar
ya def not a pretty site, but if its possible the head will only cost me 40$. he said a valve broke when he was driving. looks like he drove a long way like that lol.
Old Aug 16, 2012 | 04:37 AM
bks84's Avatar
Loved
it would require a lot of work. for the $ youd spend fixing it, you could find one in running condition, for less.
dont buy it.
Old Aug 16, 2012 | 05:53 AM
MR.johnson's Avatar
Scrap.
Old Aug 16, 2012 | 07:11 AM
turbohatch96y7's Avatar
If the head isn't bare that's still a deal.
If there's valvetrain, lma's, cams, etc I would pick it up for 40 bucks
Old Aug 16, 2012 | 07:26 AM
kickadog55's Avatar
Ya its complete, minus the broken valves. But there's a shop here called heads up inc. That specializes in this kinda stuff I may call them for a quote.
Old Aug 16, 2012 | 09:11 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
honestly you probably could repair it, just take a dremel to it and take out all the sharp edges. and a valvejob should fix it up fine.
Old Aug 16, 2012 | 10:58 AM
MonkeyMagic's Avatar
dont buy it.
this x100000000000000
not sure if srs...
Old Aug 16, 2012 | 02:21 PM
kickadog55's Avatar
Lol ya i think im gonna pass on it. and i couldnt tell if he was srs either.
Old Aug 16, 2012 | 03:10 PM
Can yyou pm me the sellers info????
Old Aug 16, 2012 | 03:15 PM
kickadog55's Avatar
hes on seattle cragslist but i can send the ad if you like
Old Aug 16, 2012 | 06:02 PM
Sparky!'s Avatar
Ouch, looks like that made a lot of noise too.
Old Aug 16, 2012 | 07:43 PM
if the head isn't cracked, and you have free time. why not repair it?
Old Aug 16, 2012 | 07:46 PM
doood's Avatar
been there done that
with a dremel? that chamber needs A LOT of work.
Old Aug 16, 2012 | 07:48 PM
Not exactly a "dremel" i was expecting someone to correct me and provide the correct tool. my machine shop has what seems like an industrial sized dremel and it'd clean that up REAL quick. i've had a head fixed that was similar to that and it worked perfectly. the spark plug hole looks like it needs a small bit of cleaning, and maybe a quick re-thread and it's good
Old Aug 16, 2012 | 08:00 PM
doood's Avatar
there are chunks missing from that chamber. it's gonna need some welding and reshaping.
Old Aug 16, 2012 | 10:05 PM
kickadog55's Avatar
Ya if you look close pieces of the valve chamber are broken out, along with the the sparkplug chamber. Would take a lit of welding and "grinding". I can't imagine it'd ever be prfect again. Plus I need a head to use for a turbo build. I can't imagine when fixed, that it'd stand the xtra pressure.
88 EF Hatch
Jun 12, 2010 02:37 PM
OUBob
Jan 9, 2009 02:57 PM
CeeJayy
Apr 6, 2007 07:46 PM
VTEC-DA
Dec 13, 2002 03:30 PM
baonest
Jul 17, 2002 06:41 AM
