Bad fuel pump??
Old Aug 15, 2012 | 06:35 AM
andyvaj's Avatar
Default Bad fuel pump??
Here is my issue.... My car would start fine in the mornings or on cooler weather it seems. I have trouble starting my car when it gets hot out or if the car has been sitting in the sun for awhile. Any idea what is causing my car not to start on hot days? It will turn over but seems like its not getting fuel... Thanks in advance.
Old Aug 15, 2012 | 07:07 AM
Former User's Avatar
Default Re: Bad fuel pump??
What car?
Resolder the main relay.
Old Aug 15, 2012 | 08:14 AM
meda215's Avatar
Yea wats ur setup first
Posted from Honda-tech.com App for Android
Old Aug 15, 2012 | 08:34 AM
ultm8mind's Avatar
Ignition starter switch $60, pretty soon it'll quit completely. I just replaced mine Monday, I thought it was a fuel issue too.
Old Aug 15, 2012 | 09:03 AM
andyvaj's Avatar
90 civic dx hatch w/b16...
Ill try to switch out the ignition starter switch then. Thanks
Old Aug 15, 2012 | 09:28 AM
Main relay is a much better fit with your symptoms. And resoldering is inexpensive and relatively easy.
http://techauto.awardspace.com/mainrelay.html
Old Aug 15, 2012 | 09:43 AM
v4lu3s's Avatar
RTFM
i agree with ron, dont waste your money on an ignition switch when the symptoms are a perfect match for main relay.
Old Aug 15, 2012 | 09:44 AM
andyvaj's Avatar
Ok. Thanks. Ill check and switch my relay. Thanks
acidburn2k2
Dec 10, 2009 06:25 AM
rsanders21
Oct 30, 2007 10:22 PM
squirrels
Jul 20, 2005 12:37 PM
MaukaRunner
Dec 9, 2003 06:09 PM
