reverse lights stuck on even when switch is unplugged
Old Aug 13, 2012 | 09:34 PM
redfire106's Avatar
10 Year Member
Default reverse lights stuck on even when switch is unplugged
Just bought this car a month ago. recently I noticed that the reverse lights where unplugged and without bulbs, so i put in bulbs and hooked them up, but when I turned on the ignition, they stayed on in every gear. I checked the switch on the transmission but when i disconnect it the lights are still on. So the question is; has anyone else ever had this issue?
car is a 91 CRX DX with a Multi-port swap.
Old Aug 13, 2012 | 10:01 PM
Former User's Avatar
Default Re: reverse lights stuck on even when switch is unplugged
Shorted plug?
If you remove the reverse lights fuse, do they now turn off?
Old Aug 14, 2012 | 07:49 AM
whited's Avatar
CRX God
The circuit is probably a grounding circuit, and the wire might be grounding somewhere else. That would be the one reason.
It could also be the opposite, where it is missing a ground causing the light to stay one. That is less common of a wiring type on Hondas.
Probably a useless post, but in summary trace your wires.
Old Aug 14, 2012 | 08:57 AM
4drEF's Avatar
Keyboard Humorist
Was the car also a manual trans swap?
Trans switch provides power.
If you remove fuse 1, lights SHOULD go out unless the wiring has been tampered with.
If they stay on with fuse 1 out, then maybe somebody spliced the reverse lights in with the wrong power circuit.
Old Aug 14, 2012 | 11:47 AM
ghosthatch's Avatar
are your bulbs swapped? maybe those are your brake light bulbs?
Old Aug 16, 2012 | 04:49 PM
redfire106's Avatar
10 Year Member
no it's not a manual swap,but it is a multi port swap They stay on even when the fuse is pulled, and also, i traced the wiring from the switch and it goes directly to the ecu, at least it looks that way
Old Aug 16, 2012 | 04:53 PM
Which fuse did you remove?
Unplug the other dash fuses one at a time to see whether removal of one turns the lights off.
If none is found, then do the same with the hood fuses.
Old Aug 16, 2012 | 06:13 PM
redfire106's Avatar
10 Year Member
I removed the back up lights fuse. But I tried removing other fuses like you suggested and when I pulled fuse #14 (alternator solenoid) they went out(also got a check engine, but i think that's normal)
Old Aug 16, 2012 | 06:50 PM
When you remove fuse 1, do the turn signals stop working?
Old Aug 16, 2012 | 07:08 PM
redfire106's Avatar
10 Year Member
yea, they stop working. The beeper and the brake light in the cluster stop too.
Old Aug 16, 2012 | 07:14 PM
It appears that somebody may have cut the Yel power wire (from fuse 1) for the reverse lights and spliced the reverse lights Yel wire with the Blk/Yel power wire from fuse 14. Look for this cut and splice.
Old Aug 24, 2012 | 06:29 PM
redfire106's Avatar
10 Year Member
I have not found the problem yet, but i think I'm getting close. when I disconnect the main harness on the drivers side, the lights go out.
Old Aug 26, 2012 | 10:41 AM
redfire106's Avatar
10 Year Member
does any one have the pinout for this connector? all the ones I've seen do not have the green/black wire listed.(Driver's side shock tower 14 pin)
Old Aug 26, 2012 | 12:56 PM
Do the diagrams at the link below help?
https://honda-tech.com/forums/showpo...7&postcount=20
Old Aug 26, 2012 | 01:18 PM
redfire106's Avatar
10 Year Member
Yes, thank you, they do help. I found out that the GRN/BLK wire that goes to the cabin is connected directly the the BLK/yellow on the engine harness. it looks like the P.O. either re-pinned the connecter or used a different engine harness. Tomorrow I'll have to follow the sensor wires from the sensor to the connecter and see if they're connected correctly.
Old Aug 26, 2012 | 02:03 PM
The BackUp light switch gets voltage from the Yel wire protected by 10A fuse 1. After the switch, the wire changes to a Grn/Blk wire, which runs to the BackUp lights.
Old Sep 5, 2012 | 03:40 PM
redfire106's Avatar
10 Year Member
so I traced my wiring to this connector (connector 402 in the helm manual)
Found the power wire and the switch wire on the same side of the connector( the 2 bright yellow wires on the left connector). I de-pinned the connectors, jumped them with a paper clip and made the reverse lights work the way they are supposed to.
the weird thing about it is that the left connector has all pins filled and the right connector has about half, leaving me wondering if the connector was re- arranged some how. if anyone currently has the dash out of their CRX, can they post pics of this connector? (it's clipped to the firewall up by the fuel lines in the left side of the dash)
Old Sep 6, 2012 | 11:53 AM
4drEF's Avatar
Keyboard Humorist
Sounds like somebody swapped a harness from an auto.
Old Sep 6, 2012 | 01:10 PM
redfire106's Avatar
10 Year Member
any other way to tell if the harness was from an automatic?
hondacivic7007
Aug 27, 2017 10:04 AM
Canadian_EF
17
Jan 9, 2017 06:02 PM
AnalyzeThis29
Lighting
Sep 26, 2015 02:11 PM
Leviatard
Mar 27, 2014 06:37 AM
90DB1TegSedan
May 20, 2012 08:33 PM
