Both reverse lights not working I have a Honda Civic 1990/91 1400 -
Both reverse lights suddenly not working - what is it likely to be and where do I find the fuss or gear switch or is it likely to be something else? All other lights are working.
Re: Both reverse lights not working I have a Honda Civic 1990/91 1400 -
Check every fuse in the car, because its free and takes no time.
Replace both bulbs. If that doesnt do it, the switch is threaded into the transmission. Disconnect it, jump the terminals and see if the lights turn on, if they do, replace the switch.
i had the same problem ....i looked at the wires going back to the transmission .....they are yellow and green i believe ......make sure they are plugged in on the transmission ...mine were not plugged in all the way and thats the reason they didnt turn on.....also if youre hardnest is cracking check it from there sometimes the wires are ripped apart ....my friend had that problems aswell ....hope this helps u ...
Canadian_EF
17
01-09-2017 06:02 PM
redfire106
18
09-06-2012 01:10 PM
