B16 cranks but won't start.
I just swapped in a sleeved b16.
Long story short my car was sitting for bout 6 months so I drained the gas and put in new gas and car started but it ran like **** due to me putting a throttle body gasket upside down. So I flipped the gasket and try to start it nothing. It cranks it has spark its getting fuel all sensors look like its hooked. Timings dead on.
Please HEEEELLLLPPP
Thanks
Please HEEEELLLLPPP
Thanks
Is you battery fully charged??
What's the voltage under a load? (Cranking)
Are you absolutley sure you have spark??
Disconnect the banjo bolt on your fuel rail or just barley crack it open and with a rag around check for the presence of fuel.
Can you hear the fuel pump prime? Main relay click?
Check for 12v at each injector. (Blk yellow wire)
Last but not least since your timing is dead on check for compression.
No problem that's often the problem after messing with a car and working on it having the doors open and trying to crank the engine over on a low battery. Especially when its been sitting so long.
This is why a multi meter is very imporant, and why I always recomend buying one.
JDM Freakk
Jun 21, 2011 05:36 PM
Vtecme92
11
Jun 17, 2006 04:13 AM
