Suspension & Brakes Theory, alignment, spring rates....
weird problem with my brake
Old Aug 12, 2012 | 02:50 PM
allmotorfreak's Avatar
Default weird problem with my brake
I just did a 4x114 conversion on my civic and i can get a hard pedal,
things i have change
-complete 96 itr brake conversion
-accord v6 front caliper with 92+ vtec lude 11.1 rotor
-booster/master from a ITR
-stock prop valve for now, i have a 40/40 waiting.
so the prob is, all my 4 calipers are perfectly bleeded but i have no pedal and nothing is leaking.
got any ideas what it can be?
the master isnt good?
thanks
Old Aug 12, 2012 | 05:03 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: weird problem with my brake
Originally Posted by allmotorfreak
I just did a 4x114 conversion on my civic and i can get a hard pedal...
Which is it? Do you have a hard pedal, or do you have no pedal?
Old Aug 13, 2012 | 09:10 AM
no pedal
Old Aug 13, 2012 | 12:19 PM
MAD_MIKE's Avatar
MM Gruppe B
Did you bench bleed it?
Is the MC new or used?
Did you overstroke/floor the pedal?
Old Aug 14, 2012 | 02:20 PM
the bleeding process was perfect
its a used mc from a jdm shop
and maybe my gf overstroke the pedal....:/
Old Aug 14, 2012 | 07:28 PM
MAD_MIKE's Avatar
MM Gruppe B
With older/used MCs you do not want to floor the pedal. Over time, crud/corrosion can build up in the area of the bore that is not normally traveled by the pistons in the MC. That area can scuff/damage/cut the piston seals, this will fail the MC.
If the MC had been sitting around empty/dry for a while the seals were most likely already bad before you even bolted it up.
Two things that are never worth chancing used/rebuilt, unless you know the complete history, are water pumps and master cylinders.
Old Aug 14, 2012 | 11:43 PM
perfect, i'll buy a new one.
thanks
vmolla1
Jun 15, 2013 06:39 PM
vsi1600
10
Feb 8, 2010 02:10 AM
vtec6200
Suspension & Brakes
44
Dec 22, 2008 03:26 PM
daniel_yu
May 20, 2008 05:35 AM
Lil Red CRXsi
Suspension & Brakes
11
Apr 24, 2005 07:06 PM
