97 R motor hydrolocked
Old Aug 12, 2012 | 06:18 AM
knightviper's Avatar
Default 97 R motor hydrolocked
i was driving on a rainy day the other day until a big puddle comes up i have a long cold air intake water got inside the motor now it doesnt wanna crank over could be possibly a bent rod or might need a cranshaft i wanna know how much my car worth was thinking about sellin it complete 97R clean title
Old Aug 12, 2012 | 06:22 AM
teg97's Avatar
Default Re: 97 R motor hydrolocked
have you tried to spin the crack over by hand with a socket and breakerbar?
Old Aug 12, 2012 | 06:26 AM
highroller54's Avatar
pull the spark plugs, put it in nutral, does it turn over by hand? If not can you turn it backwards?
Old Aug 12, 2012 | 06:29 AM
I tried all that already it doesnt wanna turn over i also took out the sparkplugs disconnected the fuel pump tried cranking it the motor just clicks :/
Old Aug 12, 2012 | 06:43 AM
teg97's Avatar
hmmm good possibility it is hydrolocked
Old Aug 12, 2012 | 06:47 AM
JuggerNaut-CTR's Avatar
Biggest reasons why cold air intakes are utterly worthless...too many cases of this happening.
Old Aug 12, 2012 | 07:03 AM
yea i know it sucks my mechanic going to take the block apart and go from there
Old Aug 12, 2012 | 08:48 AM
Dave_B's Avatar
i wouldn't even pay the mechanic. Put the car up on jack stands, pull the pan and look for damage.
Also, pull the plugs, then drivers front wheel. Try to turn the motor over by hand at the crank.
Also, you could look down the spark plug holes and see if you see any damage.
Old Aug 12, 2012 | 08:56 AM
coolhandluke's Avatar
I would only pay a mechanic to break down the motor if you plan to rebuild it. Otherwise you are dumping money. The car will definitely be worth more with the original motor. You may also want to check with your insurance company, as some premiums cover hydrolocking the motor.
Old Aug 12, 2012 | 06:10 PM
John M's Avatar
Try to turn it over by hand
Old Aug 12, 2012 | 07:24 PM
Just a n00b's Avatar
Accident Prone
How useful are the bypass valves?
Old Aug 12, 2012 | 07:37 PM
JDM CTR '00's Avatar
Not that useful, a buddy of mine had the bypass valve and he still managed to suck up water.
projekt-sol
18
May 1, 2008 11:37 AM
Madrek
22
Jul 20, 2005 05:38 PM
mcgee*
33
Jun 10, 2005 09:37 PM
damn_import_culture
Mar 1, 2005 01:37 PM
brads94accord
May 18, 2003 05:45 PM
