BBK INTAKE MANIFOLD PROBLEM! please help!
Old Aug 11, 2012 | 10:01 AM
Skunk2DC2's Avatar
Default BBK INTAKE MANIFOLD PROBLEM! please help!
Ok guys so my buddy bought a 2001 Integra GSR wit a swapped Jdm B18C SiR from Hmotors he decided he wanted 2 removed the snail manifold and put a aftermarket 1 so he went and bought a BBK Intake manifold, so after installing it we plugged everything right up, after we turned on the car it started 2 rev it self 2 9,000 rpm so we shut it off i unplugged the IACV and it sits idling at 1 1/2 rpm but wen i plug back the IACV it starts 2 idle real high like ur slamming the gas pedal but can any1 help please any info will help!-
Old Aug 11, 2012 | 11:07 AM
mouab18c1's Avatar
Default Re: BBK INTAKE MANIFOLD PROBLEM! please help!
Check your throttle body cable and vacuum leaks.
Old Aug 11, 2012 | 12:09 PM
HondaPartsHero's Avatar
Technical Hero
Vacuum leak and check the throttle cable looseness
Old Aug 11, 2012 | 12:30 PM
Skunk2DC2's Avatar
I checked all plugs on the back and dey r all tight down and i sprayed the lines wit starter fluid and i find no leaks at all i think its bcuz we r using the stock throttle body cuz i found a little gap where i think is my leak ill make sure 2 post a pic soon
Morford3288
Engine Management and Tuning
Jul 14, 2013 08:17 AM
Tylerjdmgsr
May 15, 2011 02:31 PM
kwh924
Mar 1, 2010 02:18 PM
EJ ITO
Oct 30, 2007 11:36 AM
kings1ey
Apr 28, 2006 12:52 PM
