Help please. Throttle stuck on newly boosted integra!
Old Apr 27, 2006 | 06:35 PM
kings1ey's Avatar
Default Help please. Throttle stuck on newly boosted integra!
Hey,
I have a 95 GSR turbo, and I just finished installing everything, but I came across a problem.
My problem is that when I start the car, instead of idling, the car revs to redline by itself. Well not to redline yet, becuase I shut it off before it hits 5k. Even when I disconnect the throttle cable, it still does it. Anyone have a clue? I dont check Honda-Tech that often so email me at kings1eyguy@yahoo.com if I dont respond to posts. Thanks! Im tuning tomorow so I hope I can fix this tonight. =P Thanks in advance
Old Apr 28, 2006 | 09:16 AM
exotik4doorcivic's Avatar
Default Re: Help please. Throttle stuck on newly boosted integra! (kings1ey)
you have a vacuum leak somewhere on the intake manifold, this happened to me and it turned out to be a popped of vacuum line so i got some zip ties and fixed the problem
Old Apr 28, 2006 | 09:29 AM
dornon13's Avatar
Default Re: Help please. Throttle stuck on newly boosted integra! (exotik4doorcivic)
is your iacv on tight that happend to me and mine was hanging on by one bolt
Old Apr 28, 2006 | 09:53 AM
Muckman's Avatar
Moderator in Chief
If its reving to redline then he has a HUGE vac leak. Should be very easy to find.
Old Apr 28, 2006 | 12:52 PM
mike1114's Avatar
Default Re: Help please. Throttle stuck on newly boosted integra! (Muckman)
Your throttle body is stuck open. Get carb cleaner and spray it in there and wipe it out the best you can. Hold butterfly open and clean as much as possible.
Or you have your throttle cable on too tight and it is holding the butterfly in the throttle body open.
Mcdc2
Feb 3, 2009 02:30 PM
Bakersfieldgsr
Nov 12, 2007 03:34 PM
EJ ITO
Oct 30, 2007 11:36 AM
g2b2
Mar 14, 2007 06:47 PM
WAFFLES
Apr 25, 2003 01:42 PM
