94 Accord LX auto
Old Aug 9, 2012 | 06:28 PM
hondaaccordf23's Avatar
Default 94 Accord LX auto
Thinking about buying for my sister,
Guy said it has trouble getting into first gear what could cause this problem and the car is 900$ what do you think I should go if I decide to buy it
It also overheats(maybe a thermostat), and TPS
Old Aug 9, 2012 | 08:12 PM
maystg's Avatar
Default Re: 94 Accord LX auto
Not going into first gear could be shift solenoid? overheating could be that, cooling fans, water pump. Depending on your budget I'd shop around, Unless these are small easy to fix problems
Old Aug 9, 2012 | 08:26 PM
furious94ls's Avatar
Pass it up.
Old Aug 10, 2012 | 05:54 AM
gary95H22Accord's Avatar
If its the tranny it could be $$$. Overheating could be radiator, thermo, coolant, and headgasket. Given the problems I'd say offer the guy $600, and if not pass
Old Aug 10, 2012 | 09:26 AM
Janet@bisimoto's Avatar
Hmmm...
Old Aug 10, 2012 | 05:53 PM
Mike518's Avatar
If it's full of coolant, and the radiator fans are working, I wouldn't buy it. A radiator is an easy fix, a head gasket, not so much. Not to mention if the guy has been driving it with a bad head gasket, damage has been done.
Edit: If he lets you swap the thermostat on the spot, it won't cost you much. If that fixes the problem, it might be worth it. But who knows about the first gear problem...
Old Aug 10, 2012 | 06:34 PM
nus_dogg's Avatar
I wouldn't even bother with that car. It could turn into a nightmare/money pit.
Old Aug 10, 2012 | 07:41 PM
Thats what I thought just pass it up thanks for your inputs
Old Aug 12, 2012 | 08:21 AM
Bad_dude's Avatar
Don't buy it. $900 could turn into thousands and you will regret. Don't spend your precious time at the shop week in and week out. Unless you know how to restore a car, don't take this option. Even for $200, it's just not worth it.
Old Aug 12, 2012 | 03:51 PM
rival12's Avatar
If you were a mechanic, and have ease with swapping transmissions, sure!
Synchrotech sells some automatic transmissions....or Gearspeed...(rebuilt) I swapped an H22a in mine, Motor, Trans, Ecu....Never regretted it.
Depends on your plans, budget, people rarely fix automatic honda transmissions. They are tough to clean, and pull apart. I have done this. The rebuild is timely, and unless cleaned properly fail shortly after.
Synchrotech will rebuild yours.
Old Aug 17, 2012 | 09:34 AM
94cd5c_me_go's Avatar
i say if u like to gamble do it. it may b simple but if u just starting out with mechanics pass it up
Old Aug 17, 2012 | 06:48 PM
shoe bought a 93
jasb750
Jul 7, 2013 06:05 PM
SW20FL
Jul 28, 2011 07:41 AM
KLUE
Oct 26, 2009 03:24 PM
J-Ra
May 25, 2006 05:03 PM
B17AGSR
Jun 8, 2004 07:23 AM
