f20b turbo ek coupe need help
ok honda tech i have an jdm f20b swap in my car with an ebay turbo kit i just installed a brand new moroso catch can to my motor and its giving out vappers alot when u drive can this be cause by blow headgastket because i just changed the oil n it was very milky i put brand new oil and started the car n its not milky anymore i drove it around and stil not milky but its still smoking thru the catch can. another thing the car wont stay on any ideas please i need help. thank you
Do a compression test to be safe. It sounds like a bit of blowby. I have a f20b also. I had it tuned but man even with the thick head gasket I still blew 2 rings. Mine had a thick mist coming from the catch can.
Who is Mr Robot?
milky oil = headgasket.... its toast.
unless you've somehow mis-routed lines and are forcing air into the crankcase
