Question regarding oxygen sensor wiring
Old Aug 7, 2012 | 04:49 PM
holmesnmanny's Avatar
Default Question regarding oxygen sensor wiring
Im running four shielded wires to ecu. I cut into the wires just before the ecu connector and have white green, orange black, and white spliced ifrom the o2. When I got to yellow black I got to thinking.... I see that white green and yellow appear to join with other sensors. Did I just cut off the ground to other sensors? Would I cut off the power by wiring straight to the power pin for the oxygen sensor ?
I finally threw a code for o2 sensor...1. Tho there is continuity from the o2 connector to the ecu connector on all four wires I think something is bad. I get continuity through the c210 connector with three but strangely white green doesnt test good for continuity through it but still manages to reach the ecu connector.
Old Aug 7, 2012 | 10:55 PM
Default Re: Question regarding oxygen sensor wiring
bump
DRatedA.W.D.
Sep 2, 2015 08:25 PM
holmesnmanny
Aug 11, 2012 12:33 PM
civic_driver
Feb 23, 2006 09:24 AM
kizner
Jan 22, 2006 04:22 AM
Ls1 FD3s
Apr 14, 2005 11:25 PM
