motor wont turn over by hand
Old Aug 6, 2012 | 08:14 PM
jspecwhore's Avatar
Default motor wont turn over by hand
so im trying to turn the motor over (D15b) with a ratchet by the crank pulley and the car doesnt want to turn over, it turns a 1/4 turn stops and wont go further. i pulled the spark plugs out as well so it can help out but nothing. im trying to turn it over so i can align the flex plate with the automatic clutch plate and bolt them together. i purchased this motor from a local importer as well. motor looks really clean i doubt its damaged internally but i wont rule that out. any help is appreciated
Old Aug 6, 2012 | 08:17 PM
Former User's Avatar
Default Re: motor wont turn over by hand
Is it properly timed?
Old Aug 6, 2012 | 08:41 PM
jspecwhore's Avatar
yes, exactly how it came from the importer, timed and all. now i unbolted the tranny from the motor and mysteriously it spins. now it spins kinda rough, not smooth like most of the motors. and every time it spins around it sounds somewhat dry coming from the cylinders but there is a noise coming from the flew plate sort of a small rubbing effect somewhere
Old Aug 6, 2012 | 09:19 PM
EmminoDaGreat's Avatar
Was it in gear?
Old Aug 6, 2012 | 09:39 PM
jspecwhore's Avatar
Originally Posted by EmminoDaGreat
Was it in gear?
nope, now my preditcion is that the flex plate is rubbing on the main seal cover. i will pull that off tomorow to confirm
The Punisher
Apr 17, 2010 09:05 AM
redline_customs
Nov 11, 2007 06:55 PM
Dj^BaNNeD
Jul 12, 2006 09:40 PM
navin
Jan 26, 2004 12:00 PM
See Are X
Nov 9, 2003 09:09 PM
