LS vtech sol clutch issue
I'll start by saying I have been looking for a thread to help me with this problem but none have all these symptoms...
I have a freshly built (1200 miles in last 3 weeks) LS vtech turbo del sol 93' with brand new stage 4 hydraulic clutch with lightweight fly wheel. The clutch has maybe 2000 miles on it.
Problem when engine cold: after car is started the RPMs drop when clutch pedal is pushed in and slight pulsing in pedal.
Problem when engine is warm: RPMs still drop when clutch pedal is pushed in. Pulsing gets worse and sounds almost like a knocking noise when pushed in. When pushed in and engine us reved, makes louder knocking, more rapid pulse of pedal. When my foot is resting on the pedal pulsing is still felt all the way thru pushing to the floor. When driving there are times when I push the clutch in and the pedal does not come up, I need to put my foot under it to get it to come back up. Also when driving the clutch fluctuates in engagement when clutch is released. The clutch is not nearly as hard to push as it was 3 weeks ago when I got the car back from the tuning shop.
What I have done to "try" and fix:
- replaced slave cylinder
- bled clutch both cold and warm engine
Also, I should mention that the car is only half tuned, and from my understanding when the motor gets more broken in (over the last 1200 miles) the fuel, air, and overall tuned should be modified. Is this correct? It goes back into the shop today to get the tune finished. They didnt finish it the first time because the Tial wastegate was leaking boost so I had to have an O-ring replaced from a manu defect. I wanted to see if this was an issue as I was going to try and fix the problem before I bring it back in for the tune.
If this were a clutch issue would the shop who built the motor, did the tune, and put the motor in the car be to blame? Again, the clutch has maybe 2000 miles on it.
BaronVonZ
May 22, 2008 07:48 PM
