98 Integra smoking HELP!
Old Aug 5, 2012 | 10:37 AM
packerman1966's Avatar
Default 98 Integra smoking HELP!
HELP! Hey guys i have a 98 integra had head redone due to burnt valve, seals were done and head surfaced, after putting head back on car started 1st kick and idled/runs great, let it run for about 10 minutes, with no smoke or leaks then came the problem, if you rev it up over 2000 rpm it smokes (oil) pulled plugs and all 4 cylinders had some nice clean oil on top of each piston, pcv valve is not plugged, i have ran it probably for 2 hours total trying to figure this out, could the shop have screwed up the new valve guide seals? did a compression check and all 4 cylinders are between 190 and 195, im stumped, again oil doesnt seem to get into the cylinders unless its over 2000 rpm, any suggestions
Old Aug 5, 2012 | 11:52 AM
tonydize21's Avatar
Default Re: 98 Integra smoking HELP!
does it do it constantly everytime over 2k rpmS?if yes im assuming your rings are out when you do a compression test the only ring that you are cheking is the top one it does not check your oil ring!!people just use that as a guideline cause if the compression is low that means that the top ring is bad and by logic then the other ones are bad too but if its good it diesbt nean that the oil ring is good,and im just assuming that the head job was do the right way cause that another story but usually the rings are the ones that smoke everytime at the same rpms
Old Aug 5, 2012 | 11:57 AM
JuicedUpRice's Avatar
usually if rings are bad,it will smoke when you get on it a little..but you say you have good compression,so i would guess(with the recent head job) that the valve guide seals are screwed..
but really sounds like a problem with the rings..
Old Aug 6, 2012 | 07:50 AM
thanks guys what throws me off of the ring theory is that the car didnt smoke/burn oil before the burnt valve. it has 130,000 miles on it. what would make all 4 rings go out? i keep going back the idea the seals are somehow wrong because i cant come up with any other avenue for the oil to get into the cylinders especially all 4. theres no way it could somehow travel through the intake right im stumped
Old Aug 6, 2012 | 07:53 AM
[QUOTE=packerman1966;47698674]thanks guys what throws me off of the ring theory is that the car didnt smoke/burn oil before the burnt valve. it has 130,000 miles on it. what would make all 4 rings go out? i keep going back the idea the seals are somehow wrong because i cant come up with any other avenue for the oil to get into the cylinders especially all 4. theres no way it could somehow travel through the intake right im stumped. and if the seals are screwed what could they have done to screw them up?
Old Aug 7, 2012 | 03:31 PM
[QUOTE=packerman1966;47698681]
put a spoonful of oil in each cylinder and check compression.if it goes up significantly,its the rings.do one at a time.if your compression stays relatively the same,then you can move on to inspecting the top end.
sorry i cant help on the reason of why rings go out,they get beat up just like any other part in a car,but this test will lead you in the right direction.give us an update and post compression results.
netplaceus
11
Sep 26, 2012 09:06 AM
packerman1966
Oct 5, 2011 02:29 PM
packerman1966
Oct 3, 2011 03:59 PM
Si_chRis
May 14, 2009 09:22 AM
nevrkno
Feb 25, 2008 01:15 PM
