91 DA battery problem??? please help
Old Aug 7, 2012 | 02:46 PM
Osbjoey's Avatar
Icon2 91 DA battery problem??? please help
I have a 1991 Integra and fro some reason im getting no power in my car I thought it was my battery so i took it to get charged but still as i turn my key no light turn on or anything...
Old Aug 7, 2012 | 03:57 PM
JuicedUpRice's Avatar
Default Re: 91 DA battery problem??? please help
there is a little black fuse in the fuse box under the hood,check it.did you, by any chance,hook the battery up backwards?
if that doesnt work,try replacing the main relay under the dash.
Old Aug 7, 2012 | 04:18 PM
Osbjoey's Avatar
......didnt see any black fuse?... and no didnt backwards the battery
Old Aug 7, 2012 | 04:30 PM
fcm's Avatar
fcm
Old Fart
The main relay, [PGM-FI Main Relay] has nothing to do with batt. power.
If you get no power at all, no head lights, no dome light, no horn, and no brake lights, [all constant powers, ign. does not have to be on] then it is most likely a grounding problem, check your main grounds, batt. post and cable clamp, batt. to chassis ground, [under batt. "box"] and chassis to engine ground, [the batt. to chassis and chassis to engine ground is all one cable, do not just eyeball the connections, remove/undo them clean both contact surfaces and reconnect, making sure the connections are tight but do not over-tighten. 94
ericbikes
Apr 9, 2019 04:00 AM
ek9sb
Jan 24, 2011 05:48 AM
5poonhatch
Aug 19, 2007 07:25 PM
extensioncordy
34
Jan 30, 2007 03:38 PM
speedrcr24
Oct 9, 2006 05:14 AM
