Transmission & Drivetrain Gearboxes, Differentials, Clutches
m2a4 tranny lsd problem tore apart and found this ???
Old Aug 3, 2012 | 05:53 PM
team51's Avatar
Default m2a4 tranny lsd problem tore apart and found this ???
I have an m2a4 with lsd from tiger direct, i had a pooping noise changed everything out externally and now i am in the tranny, i have it pulled appart and found this piece of metal on the magnet, does it look familiar to any of you guys, looks like there should be more,
Old Aug 3, 2012 | 06:05 PM
team51's Avatar
Default Re: m2a4 tranny lsd problem tore apart and found this ???
pooping lol poping
Old Aug 3, 2012 | 06:19 PM
Runnerdown's Avatar
Yep that would be a broken, mangled synchro spring. Look at the brass synchros and you can figure out where it came from.
Old Aug 3, 2012 | 06:28 PM
team51's Avatar
would that bind the lsd
Old Aug 3, 2012 | 06:58 PM
team51's Avatar
My LSD has large bore hole plum thru so I say its Oem put in the a4 because it came from tiger already installed
Old Aug 6, 2012 | 02:32 PM
extralargenog's Avatar
Ugh dude, hate to break it to you, but a B4 LSD aint going in a A4 (or any other non B4 case) case sir.
Period.
The B4 case is specifically bigger across for th e larger OEM diff ;O)
The LSD "binding" if it IS in a A4 case is because, well... ITs in a A4 case.
You dont just go throwing diffs in trannys without checking preload, and that one... Well. That one wont Ever work.
Old Feb 3, 2019 | 07:43 AM
jay525's Avatar
hey I know this is old but I need some help with this.
what do you recommend since the oem M2B4 LSD does not fit the M2A4
Old Feb 4, 2019 | 07:25 AM
Aquafina's Avatar
MFactory helical LSD. Click the link in my signature to purchase.
Old Feb 4, 2019 | 04:06 PM
jay525's Avatar
thanks for the info.
m0sad
Aug 6, 2015 08:29 AM
Bobby_Budds
May 5, 2007 02:42 PM
hondaZvic
Apr 24, 2006 12:27 PM
CRX A4
Apr 5, 2003 04:04 AM
hybridhatch90
Sep 22, 2002 12:19 PM
