Brake grinding problems
Old Aug 2, 2012 | 07:54 PM
natethegreat54's Avatar
Default Brake grinding problems
Okay everyone I'm back again because when I'm In a bind this website helps a ton
Okay so a few days ago I was going onto a highway and a bone head stopped compleatly on an access road so to a avoid a collision I slammed on my breaks then they immediately started making this metal to metal grinding noise
I thought it was my break pads my dad thought it was my drive train bent but we replaced both those and it still grinds
It turns out the inside of the wheel is grinding on the brake shoe or caliper thing that hold the break pads in place.
I have no idea what is causing the two to grind
Any ideas on what needs to be adjusted or replaced would be sooooo helpful because I am just stumped
Thanks so much!
Old Aug 2, 2012 | 11:11 PM
axis11's Avatar
Default Re: Brake grinding problems
Identify which wheel is making the noise. Look for marks of meshing. Any pics, sound clip or video?
Old Aug 2, 2012 | 11:33 PM
kwijibodavid's Avatar
post a pic hard to understand what you mean did u change all the pads/shoes front and back rotors/drums they will cause a metal to metal grind sound if u didnt replace what was actually bad
Old Aug 3, 2012 | 03:02 PM
its the front left tire that is grinding on the caliper but i dont know why
Old Aug 3, 2012 | 03:03 PM
http://postimage.org/image/j0qnkt07r/
copy and paste link in address bar to see the pic
thanks
Old Aug 3, 2012 | 03:51 PM
eurochoi's Avatar
Is the rim out of round...."bent?"
Or are the bolts that hold the caliper/caliper mounting bracket...tight or even still there? Maybe a cracked spindle where the mounting bracket attaches....
Old Aug 3, 2012 | 03:58 PM
I am going to swith the tires and put the left wheel on the right and vise versa to see if it is the wheel that is causing it because it is only on the front left wheel
but all the bolts are there and tight no cracks that i can see
Old Aug 3, 2012 | 05:30 PM
u could probably go to a pick n pull junkyard they usually only charge like 25 dollars for a steel rim
Old Aug 5, 2012 | 06:09 PM
the bracket that holds the caliper is missing a bolt and that is why it is stuck out a little and is grinding on the wheel
does anyone know a website that would have a diagram of a brake system with the part numbers ?
Old Aug 5, 2012 | 06:27 PM
dpetro1's Avatar
www.hondapartsunlimited.com
Old Aug 6, 2012 | 02:47 AM
Libertariat's Avatar
Ek Forever y0!
You don't need to buy honda parts for that. You can go to your local parts store and buy a caliper bolt kit and be good to go. I managed to lose a caliper bolt during autocross season last year.
pcguy760
Apr 8, 2007 03:52 PM
93egSIboi
Feb 1, 2005 04:51 PM
sl0wED
May 15, 2004 08:42 PM
vietboixstunnah
May 10, 2003 01:00 PM
RolioPolio
Jun 29, 2002 01:38 AM
