98 civic ex -- low idle and acceleration problems
Old Aug 2, 2012 | 04:46 PM
AllAboutHonda's Avatar
Default 98 civic ex -- low idle and acceleration problems
upload this video, this is what it's doing. Also when trying to accelerate the car doesn't accelerate correctly, until it hit a certain point.
http://s1188.photobucket.com/albums/...=VIDEO0021.mp4
Old Aug 2, 2012 | 05:04 PM
90lsvcrxva's Avatar
Default Re: 98 civic ex having problem unknown
Have you checked/ replaced plugs?
Old Aug 2, 2012 | 05:27 PM
grumblemarc's Avatar
The Grumpiest
Is that rod knock I hear?
Old Aug 2, 2012 | 11:22 PM
Kohen's Avatar
Any CEL codes? How's your oil right now? Check timing?
Old Aug 2, 2012 | 11:39 PM
jdmcertified909's Avatar
that **** does sound like rod knock. sounds like a freakn diesel engine. well anyways since it happens when you let go of the gas ill say check your throttle body plate make sure it has no black soot around it if so as the vacuum pulls it shut the black soot covers the lil gap its suppose to have to keep it breathing. or it could be a open egr. and that stumble upod accelerate i would say it is egr, but if you pull the spark plugs out it will tell you whats going on with the engine
Old Aug 6, 2012 | 10:40 AM
I drain out a lot of my oil, and still it's still up on the second dot. I don't know what happen my brother change my oil. I don't know what he did to it, but I sure did drain a lot out.
Old Aug 6, 2012 | 10:44 AM
egr? I don't see it on my car I also google it and they say that it doesn't have it on my year EX. yeah I'm taking the tb off and cleaning it. what do you mean pull the spark plugs? you mean while the car is running? or??
Old Aug 6, 2012 | 11:51 AM
90lsvcrxva's Avatar
More than likely it's plugs if it stumbles during acceleration. Could be vacuum leak or bad intake manifold gasket or tb gasket. What about valves I had slight miss in gsr and it was due to bad valve. Could be a number of things but I would start with the easy stuff. Any codes?
Old Aug 6, 2012 | 02:25 PM
Kohen's Avatar
I was having a similar problem. I'd check timing for sure. Do a compression test and let us know the results. Got any blue smoke coming out the exhaust?
Old Aug 6, 2012 | 02:29 PM
CivicBlacksheep's Avatar
10 Year Member
Sounds like poor compression or the timing is off
Old Aug 6, 2012 | 05:17 PM
Former User's Avatar
Default Re: 98 civic ex -- low idle and acceleration problems
If you don't answer questions posed to you, then this thread is pointless and will be closed. See posts #2 and #4.
Low idle - Clean the IACV and adjust the idle speed.
jazz1308
Apr 29, 2013 05:37 AM
joeshmo
53
Sep 19, 2011 02:42 PM
craigers
Feb 1, 2011 07:30 AM
shutupkid
Jan 28, 2011 02:05 PM
