98 civic ex -- low idle and acceleration problems
upload this video, this is what it's doing. Also when trying to accelerate the car doesn't accelerate correctly, until it hit a certain point.
http://s1188.photobucket.com/albums/...=VIDEO0021.mp4
Re: 98 civic ex having problem unknown
that **** does sound like rod knock. sounds like a freakn diesel engine. well anyways since it happens when you let go of the gas ill say check your throttle body plate make sure it has no black soot around it if so as the vacuum pulls it shut the black soot covers the lil gap its suppose to have to keep it breathing. or it could be a open egr. and that stumble upod accelerate i would say it is egr, but if you pull the spark plugs out it will tell you whats going on with the engine
More than likely it's plugs if it stumbles during acceleration. Could be vacuum leak or bad intake manifold gasket or tb gasket. What about valves I had slight miss in gsr and it was due to bad valve. Could be a number of things but I would start with the easy stuff. Any codes?
I was having a similar problem. I'd check timing for sure. Do a compression test and let us know the results. Got any blue smoke coming out the exhaust?
Re: 98 civic ex -- low idle and acceleration problems
If you don't answer questions posed to you, then this thread is pointless and will be closed. See posts #2 and #4.
Low idle - Clean the IACV and adjust the idle speed.
jazz1308
04-29-2013 05:37 AM
joeshmo
53
09-19-2011 02:42 PM
shutupkid
01-28-2011 02:05 PM
